Khukuri Kata
Ok, I've read several places that the Nepali don't really have a kata (detailed choreographed patterns of movements practised either solo or in pairs) for the kukri, as they have them in their hands since they are young children, and know them as well as their hands.
However, most westerners aren't that lucky.
So I'm wondering, have any of you come up with a kukri kata that you use?
I decided to come up with some. Not only for practical use (how often will I really get into a fight with a kukri?), but as a good workout, and a way to make wielding the kukri through daily use so that it becomes an extension of myself.
I wish I could post pics of it, but I bought the cheapest digital camera I could find when i bought it, and it has no delay feature, and barely any memory for more than a few seconds of video -- all I wanted it for was to post pictures ont he net of things I have and things I'm selling.
Back to our original programming:
Most people instinctively think of slashing attacks with the kukri. However, the bread and butter of my routine makes use of the excellent stabbing qualities of the kukri, and stabbing attacks make the larger kukri like the Ang Khola and M43 much faster weapons, and most knife fighting practitioners will agree that you slash to wound and stab to kill.
First is a rib stab. Take the kukri back toward a position where your hand is close to your pectoral muscle. Take a step forward with the foot on the off side. As you stab forward, rotate the kukri onto its side. If used on a real person, the blade will go between the ribs and give a massive, probably fatal blow that goes in with little effort. You step forward with the offside foot to give more access to your off hand, which will be used either bare handed, or with another weapon to hook, ward off, or just deflect the other guy's weapon.
A variation of the above is a downward stab, except that you keep the blade in a vertical orientation, rather than turning it sideways (with the target being a close-up encounter with a feral hog when hunting, or an attacking feral dog or big cat. You also step forward with the strongside foot, since you won't be doing much deflecting with the offhand, and it gives better footing to lunge away after you strike.
Next, the top stab. Useful to have a practice dummy of proper height (I use stacked hay bales). Run toward the target, take a little hop and stab down between the bones of the clavicle. Orient the kukri such that the stab is headed for the opposite arm pit. The curve of the kukri will make the actual track curve the blade down into the heart and major blood vessels, and if the kukri is long enough, will likely stab into and collapse the farside lung.
The kukri whip:
Practice rotating the kukri in hand to have the spine facing forward. Then practice "slashing" attacks -- side, angled up and down, and overhead (like pistol-whipping). The trailing mass of the kukri blade makes such attacks very easy to land accurately. Good for if you want to incapacitate, but not kill (although a head strike with a heavy one will still probably kill). Good also for multiple attackers, so you can break bones, and keep moving, rather than have the blade get stuck in one target.
Then, of course, the various slashes.
I've also made some interesting discoveries when using a sparring partner (ALWAYS pad and tape the blades, and do the movements SLOWLY, when using a partner).
1.) Blade deflection. We did soem force-on-force drills with various weapons -- tomahawks, other kukri, and my Tarwar. The forward curve of the kukri serves well to deflect an incoming attack and still leave the kukri positioned for an immediate counterattack. The sharp transition like on an Ang Khola seems to work better for this. The sweeping curve on the M43 left me able to get the blade back down enough to hit the opponent in the forearm or elbow crook. At the very least it would have taken most of the meat off the other guy's forearm, and with the bigger ones -- Tarwar and CAK -- taken the guy's forearm completely off. You can change technique top keep this from happening, of coursed. With the kukri with a sharp transition, I was never able to get the blade back down for even a glancing strike.
2.) Hawk vs kukri: Tomahawks are one of the best weapons out there, and have many advantages, even over swords. However, the big thing that hawk users LOVE to do, is hook your blade. The kukri is an excellent counter for this. If the attacker is the same, or stronger than you, when he hooks your blade, simplky rotate it so that the spine is oriented toward that head, and it'll slide right off. Since he probably put considerable effort into the hook, he's now vulnerable with his primary weapon away from him and you, and a simple twist of the kukri, and you're ready for an immediate stab.
If the opponent is weaker than you, twist the kukri the other way -- hooking his hawk -- and swing away from yourself in a backhand swing, bringing up your offhand to facilitate breaking his arm. He'll either get his wrist/arm broken (in a real fight), or let go of the hawk. You are now in a good position to make a powerful slash into his abdomen, or continue your spin and come around and hamstring him.
Then, if you really want to have some fun, use the kukri in your strong hand, and a tomahawk in your other hand. :D
Any of the above are great workouts, and soon you'll find that heavy kukri isn't so heavy anymore, and its use becomes second nature.
So, does anyone else workout with their kuks?
This is actually very good...but I still miss the pictures :)
...and you are right about the weight issue...one just gets used to it (with practice) and learns to control it.
You might want to also practice moving around an attack, with khukuri in hand, and NOT using the khukuri. (and yet still surviving)
If we could built khukuri strikes AROUND evasion, then we could have a viable method, starting with Danny's suggestion.
I have a small combat oriented khukuri when it comes to fighting, due to it's small size I can apply a lot of circular movements that incorporate a simultaneous deflect and attack. I use slightly modified motions though, incorporating movements similar to what you'd use with a tomahawk (due to the forward weight). I don't have any particular linear routine, but I have certain principle motions that I try to maintain a fluid pattern in shifting through, keeping myself able to jump from one to another without limitation (like setting myself back to generate a forward moving moment, or charge).
It's not terribly heavy, so it's not a strenuous workout, but I suppose it makes for as good a cardio routine as my standard training. I plan on taking this khukuri with me to Afghanistan (maybe I'll meet some Ghurka and we'll chat about it), so training with it isn't just "fantasy" as I plan on putting it to some use if I ever get into some hand-to-hand while interpreting.
My favorite technique so far is a stab and roll, commonly found in Philippino knife fighting. Basically you stab your target, adjust their defending arm to a position that places them at a disadvantage, and while maintaining contact with your handle you roll your hand into an inverse position, dragging the blade out and across. This allows you to continue a steady flow from certain key positions and increases your timing in a combination attack. It's also the best way to recover from a stuck blade without losing the momentum that you generated in the first place, effectively taking what was a disadvantage and turning it into an advantage. It does however take a lot of practice and requires training in the motions everyday to maintain AND increase your speed.
It also does a great job of keeping up manual dexterity in other parts of your life, such as typing on the keyboard. :)
Other techniques are quite similar to the ones you've already outlined.
Not sure I completely catch your meaning.
You mean without striking the opponent or their weapon with the blade, or not using the blade at all? I can use the weight of the blade, and movement of it to offset my balance to get away with some maneuvers I wouldn't be able to do without a counterbalance.
I suppose I could try to work it in with my systema routine. Heck, if I can do it with a Kalashnikov, I'm sure I can do it with a kukri.
[youtube]aPD9LxbgLxU[/youtube]
Gurkha demo at shorecliffe barracks in the UK.
[youtube]njFeTJcg9bg[/youtube]
Gurkha presentation team dance with khukuri and bucklers.
[youtube]YkUuC-fBryo[/youtube]
combined
[youtube]iUP_oNOgh1Q[/youtube]
a parade, just because i like parades ;)
[youtube]H3baq5_YqbY[/youtube]
Gurkhas part 1. you can never have enough parades...
[youtube]HkajCQb2Tpg[/youtube]
part 2.
Yes, from what I know there really aren't any traditional khukuri 'katas' equivalent to what we see in many Chinese, Japanese etc. martial arts - choreographed sets of fighting moves. The khukuri drills you see the British Gurkhas perform seem to be a fairly recent phenomenon. Prior to that the closest you got was the Khukuri Dances, speaking of which, here are a few more from the Indian Army Gorkhas to complement the ones posted by Kronckew of the British Gurkhas:
3rd Gorkha Rifles (I believe 4/3 GR):
[youtube]LH9M-2LOXDA[/youtube]
5th Gorkha Rifles performing for US Army contingent in India for joint training:
[youtube]hpy7v2dLefk&feature=related[/youtube]
Great vids, guys. Thanks!
Is it just me, or does that Ghurka dance go great with bagpipes?
BTW guys, I didn't start thiks solely based on fighting with kukri, but more as a means to become accustomed to it and its weight and how it handles.
I always hear people say how they don't like kukri because they are unbalanced and heavy and you can't do fine work with them. To which I love to link to the "Kukri in the kitchen" video. :D
But I got to thinking, that if the very small by American standards, Nepali can use them seemingly effortlessly, and westerners who put in the time to learn to use them right can do it, it must be a lack of experience and familiarity. So why not do some practice moves which involve a lot of motion and changes of direction, so the use of the kukri becomes second nature?
Of course the downside could be that you won't like any kukri much after "bonding" with your chosen one like this.
Easy human spots for blade slicing attack: (think arteries, veins and soft tishue)
Neck
inside of legs or calfs
underside of arms, arm pits
With a normal khuk (not the sword types) I'm not very sure about stabbing due to the odd 90deg blade turn and broad (and wide i.e. thick) blade...it may just get too stiff between the ribs. I would rather look for a hacking / slicing motion to the above targets. With the blade nicely curved a nasty cut should be immobilising.
Great video, thank you
The American Bando Assoc. which teaches the kukri as a weapon (and was started by a former Ghurka) uses both stabbing and slashing attacks, as well as reversed blade techniques.
Turning it sideways makes it easy-easy to get through ribs. To be honest, even a vertically oriented stab would probably make it through. I rammed my CAK through a 1/2" piece of plywood. I'm pretty sure I could get it through a ribcage.
Or, the ribcage can be bypassed altogether vis a "mountain Manm grip" -- imagine holding your hand down at your side, with the edge up. Stab it in at the base of the rib cage, and the curve of the spine will force it up into the plural cavity, severing anything in its path.
And remember my goal -- not so much (just) combat. Those 90o deg turns and such teach you how to control the kukri. Control and familiarity being the primary goals of what I'm talking about.
Practice makes perfect!...now to find me a target...errr dummy;)
So. Africa? try some assegai wood* :) or an iron fence, which is probably softer.
*- Curtisia faginea or Curtisia dentata, family Cornaceae aka. cape lancewood.
My suggestion is intended to help you discover new things about fighting with the khukuri that you might not see if you "intend" to USE the khukuri in the fight.
It's a form of deliberate naivete. You move as though you have no weapon.
At some point, the weapon itself will kind of jump in and say "here! now".
It sounds crazy, I know it, but give it a chance and let me know what you think.
(yes, this is ninja fighting, but I dont know anything else, really)
my background is FMA and stickfighting. I felt it was a natural progression to move to machettes and decided to use the Kuhkri...
I actually need to pick up a new set of Kuhks...<off to search the interwebs>
