Originally posted by Drdan
I realize that a golok is probably a good choice over a standard machete, especially if one is willing to pay $40--$50 and even a lot more for a high quality golok...
I'd love to see comparisons with a 20"--24" overall length golok or parang with a similiar overall length lighter weight khukuri. Let's assume that the tester is not biased, and has experience chopping and slicing with axes, khukuris, machetes and goloks (and related blades). I've heard that a khukuri has a tendency to glance off targets if one is not accustomed to using it. I'm sure a machete or golok would have its foibles too, if the tester only had previous experience with axes. With any blade, it is asumed that the tester has experimented and become familiar with the blade before valid comparisons are made...!
It would be interesting to see how each blade fares with 4" banana trees, chopping small diameter green and dry wood, 1" and 2" diameter vines, and even more vigorous chopping tests.
Knowing that the khukuris "sweet spot" is traditionally hardened, it would be fair for someone well versed in the use of a khukuri to chop in that area, not near the tip or the handle. Conversely, it would be only fair to chop or slice with the golok or other non khukuri blade using said blade's sweet spot. It's obvious that the golok would not fare well if its tip were used for chopping; indeed using its tip in this application would REALLY test the strength of both its handle and partial tang!
None of the testing I've reviewed is really in depth; although those 3 tests conducted by Cliff Stamp, and linked in the HI website, seem to be the most unbiased and thorough. Maybe it's just me, but the golok vs khukuri testing is not very clear at all, and does not give the khukuri a fair chance.
