I used a hatchet to split the handle wood, and further used the poll to smash it. Even with the wood splintered it would not let go of the tang. With lots more effort I was finally able to remove most of it, but it did not pop off from the epoxy- the wood broke leaving a coating of fibers still embedded on the tang and pieces in the bolster. I started using a hammer to break off the epoxy, but it refused to just chip off. So I tried burning it off with a propane torch. I burned the wood fibers out but it still wouldnt let go. I had to use a hammer and chisel to get enough out of the bolster to remove it, and then finally had to grind off the excess with a dremel. If a hatchet, hammer, chisel, grinder, and a friggin blowtorch have a hard time getting the handle off, I dont think you have to worry about it flying off on its own.
