Killa Zilla v GFB Small Forest Axe
After doing a chop-off with the KZ and it's immediate "knife" competition which it was pretty emphatically the winner ... I decided to see how the KZ compared to the GFB SFA ....
Here are the two ....
I decided to take down the trunk of a tree which had been snapped by high winds as the liklihood of it growing again in the shade of nearby trees was remote and it would come in handy for firewood ... here is a pic of the trunk and I needed to drop it in the same direction I took the photo where there was a bit of a clearing ....
I started on the trunk using the GFB SFA to open out the main under cut where I wanted to drop the tree ....the Axe easily sorted this .....
On the other side I started the upper cut with the KZ .... and this was able to "bite" as deep as the Axe ....
The best photo I have to compare the two is this one ....
On the right you can see beneath the main area of cuts the last strike I did with the KZ ... the depth of the cut is very impressive and it only took a few more strikes to bring the wood removed on the upper cut down to this point ... the extra blade area of the KZ would remove more wood with each cut across the trunk than the Axe .....
The Axe however was a lot easier to use .... you needed more swings to enable the Axe head to cover the diameter of the tree ... but it was less tiring and over the same period of time they were both about equal in depth achieved... the Axe though needed to be brought down at a steeper angle to cut as deep and removed as a result a lot more wood ....the KZ could bite very deep in a lot smaller cutting area ... wasting less wood as "wood chips" and this can be seen from the following pic ....
Looking from above you can see that each had more or less gone halfway into the tree trunk ...the Axe being the lower area and the KZ the upper ... but look at the final cut on the upper section that the KZ did to cleave through the trunk of the tree to fell it .... in the hard wood section of the tree the KZ has cut as deep as the blade section of the knife and at a fairly flat angle ....which felled and dropped the tree by basically cutting it clean through .... I did I admit put a bit more effort into that one cut than the others just to see if it could do it ....and I was quite suprised with the way it managed it .... I tell you ...there is a LOT of power you can put into this blade :eek::thumbup:
You can see the flat top cut and more angular under cut in this pic together with the trunk where it fell ...
It is not a clear pic because by this stage my hands were shaky from chopping and round the back of the trunk is the KZ embedded in and just sticking out on the left hand side ... but it gives you an idea of the two cuts and where the trunk dropped.
The next stage was to tidy up the stump and flatten it out .... I used the KZ to trim off the wood from the top cut down to the lower one .... again it was an easy task for this knife ....
The hardest task of the day though was picking up the log to tidy it away and put it with the others from the upper snapped off section ... it weighed a ton ...:D
My conclusion on this is if you had to do a few trees then the GFB SFA is a fair bit easier to use and less tiring ... but if wanting just one large tool to put in the rucksack for all eventualities ... the KZ takes some beating :thumbup: Able to do the job of an Axe and a lot more other tasks as well ....
nice review mate - anytime you want to send that khuk to me to drool over let me know !!
I'd love to just hold it !!
Awesome review! Thanks! I might even have to buy another one. I don't know why people are not buying the crap out of these now at the reduced price they seem to be going for unless they never go out in the bush. I am waiting for my next trip in the Alaska bush to take pics with.
Great review Peter! I had figured the KZ would keep up pretty well after some time I've spent with it out in the woods, but without an axe I wasn't able to do a proper comparison.
Thanks for doing one and including pics to make the review come alive!
excellent review, great pics and a lot of hard work, thanks for your time and review, the kz is an awesome chopper.
Great comparison photos. One question I do have is after cutting with each of the blades which one got stuck in the wood and needed to be pulled out more?
Thanks
Nice review! Btw I like your avaitar... you don't see too many dogs with M79's. One of my favorite toys ;-)
Nice review Peter, :thumbup: You keep swinging that KZ everyday like that, and you'll have arms like the hulk in no time! :D
Thanks
The Axe and the KZ both have convex shaped blades .... these tend to throw out wood chips and are easy to remove .... the thin hollow grind Hossom in an earlier review was the only knife to stick in and be hard to withdraw .... it seemed that the wood closed around the blade causing the concave hollow grind shape to "snag" if buried too deeply ....
Great chopping review and photos, Peter. I seldom even carry an axe into the bush unless I camp, which is almost never nowadays. While it is a bit heavy for belt carry, the KZ is surely a serious chopper, as you have shown us so well. But for all-around use, I'd prefer the BWM or NMSFNO. I think I'll keep my thinned out KZ for heavy yard work and wood splitting. I need to get a sheath for it so I can carry it in my Jeep. It would make a superb truck knife.
