What do you mean, it takes a while to get a good edge?I have a King 6000grit waterstone and it leaves a good finish but cuts a lil slow.
It doesn't remove alot of metal and takes a bit of time to get a nice polish.What do you mean, it takes a while to get a good edge?
If you're sharpening mostly carbon and fine-grained stainless (i.e. the Sandvik steels and a few of the powdered steels other than S30V/S60V/S90V), the King 6000 will be wonderful as either a last step or step before stropping. If you're sharpening mostly D2, S30V, and ATS-34 type steels, it may prove frustrating.
Why would it prove frustrating because it will take forever?
Can you recommend something that will work better?
Exactamundo.
Wet/dry sandpaper on a hard, flat surface. Its silicon carbide abrasives cut through highly-alloyed steels like S30V with ease. Don't be alarmed that it only reaches 2,500 grit as American sandpaper and Japanese grit systems are in no way equal and silicon carbide is pointier than the aluminum oxide and chromium oxide used in most fine-grit waterstones (so the 2,500 grit wet/dry paper is finer than an 8,000 waterstone and leaves an even finer finish). And it initially costs less, too.
