I just completed my first knife with a frame handle. This was a small petty knife made from 0.06" thick AEB-L and I used a black G10 spacer between paper micarta for the handle. This turned out pretty nice and was pretty quick to do, so I want to make more. I have a few questions that I hope some of you can help me with.
The first questions is about the tolerance I should aim for between the spacer and the knife tang. For the petty knife, I happened to have a G10 liner that was a couple of thou thicker than the tang. I have two other knives I would like to use this technique on where I don't have anything close in size, and no combination of liners I have will get me there. I looked online and the closest I saw is around 10-15 thou oversize. I know epoxy will fill this gap, but I am a bit concerned about the racing stripe down the handle not being aligned with the blade. What tolerance do you think is acceptable? I can't think of a good way to reduce the thickness of a G10 liner uniformly with the tools I have. Is there a good method for this?
My second question is about the minimum height of the frame above and below the tang. I have right around 3mm on the knife I made. Does that sound reasonable? Can I go even lower? I trimmed a bit of the handle I made off the end as I had left it too long and ended up with a 3mm cut-off that I put in the vice and broke with a hammer. It took a lot more force than expected and while it failed at the glue line, about half the fracture surface had micarta on it, the other half looked shiny. I used West Systems 105 epoxy for the glue up and it appears that the glue joint is about as strong as the material.
My third question is about the best way to get a small pin in the handle like shown in the little sketch. Do you drill the hole in the tang first and try to drill the hole through the handle in the right place, or do you drill the hole in the handle first and then transfer that to the blade and drill it with a carbide bit? Or do you assemble only half of the frame handle and use the hole in the tang as a template for drilling? Also, how much metal do I need to leave above and below the hole in order not to weaken the tang excessively? Would a 3/16" hole be ok in a 3/8" tang?
As always, any help is greatly appreciated.
