- Jun 27, 2016
Just looking for opinions of kitchen knives that everyone should have. I want to go past the chef, bread, paring. What are some more specific types and styles someone who cooks a lot should have or look at?
did you like a 90 deg tip or a rounded one? also what type of grind did you prefer, thick/thin/convex/etc?I used to use Nakiri's a lot for veggie prep. I use a long sujihiki for slicing stuff, too.
can you be more specific about the grind on the nakiri? are you saying its s ground?The basic three knife kitchen set is chef's knife (gyuto), bread knife, and paring knife. That being said, my knife rail usually contains the following:
10" bread knife (longer is almost always better)
260mm sujihiki (slicing knife, could be longer)
230mm gyuto (chef's knife)
170mm nakiri (flat edged vegetable knife)
150mm honesuki (thick, rigid poultry boning knife)
150mm petty knife (utility knife)
90mm paring knife
My nakiri sees the most use because I ground a heavy relief on the side of the blade so food release is phenomenal. The next most used is my gyuto which get used for absolutely everything, from bread to meat to pizza to vegetables. The bread knife only comes out when I have a particularly soft loaf with a thick crust that my gyuto can't break through without crushing the inside.
Yes, it's an asymmetric s-grind. I started with 0.084" stock, ground it to zero somewhat thicker than I usually do so there's plenty of meat in the middle of the knife, then ground a hollow only on the side that I need food release from. I used a 12" wheel and the hollow is about 1-1/4" tall, starting approximately 3/8" above the edge and finishing approximately 3/8" below the full thickness spine. I tried grinding knives much thinner before adding the hollow but ran into two problems. First, the knife would tend to warp towards the hollow really badly, easily 3/4" at the tip of the knife. It's fixable with a carbide straightening hammer but is quite annoying. The second and bigger problem is that food release is worse. The primary bevel above the edge needs to be steep enough to push food away from the hollow. If it's too shallow the food will climb the bevel into the hollow and stick. Here are some photos of the one I use every day, not the prettiest I've made but it's the only one I haven't given away!can you be more specific about the grind on the nakiri? are you saying its s ground?
For me it's just because mine has an s-grind for food release (and that's easier to do well on a very flat profile like a nakiri). Broadly speaking I prefer using a 220-240mm gyuto but I haven't made an s-grind one for myself yet.Lots of recs for nakiris here. Do y'all think that's based on your cutting style or the food you cook or something else?
i'm guessing cutting style, that our knives are more likely to be biased towards slicing. i'm liking the little nakiri i made, and i bet i eat different food to a lot here, since i only cook vegetarian food.Lots of recs for nakiris here. Do y'all think that's based on your cutting style or the food you cook or something else?
I may be wrong but I thought a Usuba was basically a more traditional Japanese knife prior to the nakiri and are pretty much always single bevel while the nakiri is a more modern knife that is almost always double bevel. The two styles tend to be almost identical and are for identical cutting tasks, the difference other than grind is Usuba tend to have more of a square rectangle point while nakiri often have a rounded point atleast from what I’ve seen.Nakiri and usuba can be made in any grind you wish. I agree many usuba are single grind.
My usuba is thin, single convex beveled, and sharpened on one side only. It has no urasuki. The secondary angle (edge sharpening bevel) is very low angle, somewhere around 10°. Blade is about 3.5" long and 1" wide.
The Nakiri is double full convex beveled, thin, and sharpened on both sides at a low angle. The blade is about 6" long and 1.5" wide.
I use the nakiri for cutting everything from vegetables to meat. The flat and moderately wide blade easily scoops up the items to put in a bowl or pan. I keep a Japanese "stone-on-a-stick" by the knife block to refresh the edge as needed. Mine has a square end, which also comes in handy from time to time as a spreading tool.
The vegetarians already wisely suggested the nakiri, so I feel obliged to recommend a good long carving knife too!Just looking for opinions of kitchen knives that everyone should have. I want to go past the chef, bread, paring. What are some more specific types and styles someone who cooks a lot should have or look at?
Oh definitely ... i especially use my boning knife for poultry ... for digging into and prying apart joints, and for deboning legs and breasts. A "boning knife" can mean different things - thin and flexible, or thicker spine, less flexible, and more robust edge. I favor the latter ... again to dig in and torque to separate joints, and an edge of something like 25 degrees per side so it does not get damaged by contact with bones.The vegetarians already wisely suggested the nakiri, so I feel obliged to recommend a good long carving knife too!
