However the problem with the Lansky/KME type setups is geometry. The further you move from where the rod intersects the guide the greater the hypotenuse which changes the vertex. Close in the difference is going to be negligible, but as you move further and further out from the center of the guide the vertex formed where the stone contacts the bevel is going to get smaller and smaller. On a 2-4" blade this isn't going to be very noticeable functionally, but the longer the blade is the more pronounced the difference is going to be. The wicked edge system minimizes this by lengthening the distance from the guide to the bevel making the vertex change less dramatic when you lengthen the hypotenuse similar distances.
I don't think that a blade flexing would be much of a concern. However the problem with the Lansky/KME type setups is geometry. The further you move from where the rod intersects the guide the greater the hypotenuse which changes the vertex. Close in the difference is going to be negligible, but as you move further and further out from the center of the guide the vertex formed where the stone contacts the bevel is going to get smaller and smaller. On a 2-4" blade this isn't going to be very noticeable functionally, but the longer the blade is the more pronounced the difference is going to be. The wicked edge system minimizes this by lengthening the distance from the guide to the bevel making the vertex change less dramatic when you lengthen the hypotenuse similar distances.
Has been discussed many times before and not true. This is one of the previous threads and is worth reading from the beginning: http://www.bladeforums.com/forums/showthread.php/1339022-angles-on-clamp-style-devices
If you do not have the patience to read it all, jump to reply #38 http://www.bladeforums.com/forums/s...n-clamp-style-devices?p=15412040#post15412040
Very interesting, that all seems very counterintuitive.
