The grind is different from one side to the other. The knife i am working on right now is a Opinel no.8 cheap knife to begin with..Snake62 I've sharpened a lot of FFG blades (think Spyderco offerings) on the KME and rarely need to tape them. You just have to get a good solid clamp, using the pinch I mentioned. Sometimes you do need to use tape but not nearly as often as people perpetuate.
Not entirely sure what you mean by uneven grinds? Are you saying the grind varies along one side, and if so, how so? Or are you saying the grind is different from one side to another?
If you have a straight-spined knife, align it with one of the lines in the clamp, I like to use the one closest to the spring as you get more bite but that's not always possible. You want to be as close to center (tang to tip) as possible. Then, as I said, pinch down on the clamp corner and tighten everything down. There should be no play. If there is, consider going a little tighter if you think there is room to do so. If not, then you might need to tape the blade. Also, if the blade as complex grinds, it may not have enough flat for the clamp to hold onto. If there's any wiggle with the blade clamped, do not proceed. It has to be secure to move on. Also, make sure there's no oil on it.
I MUCH prefer Dean O's videos to that other guy but that's just me.
