My apex edge pro does this too. All I can say is make sure you clean everything really good. I suppose the scratches are coming form grit particles from the stones. I just started covering the blades with masking tape so I don't have to worry about it.
The scratches are coming from the grit coming off of the stone, not metal particles. As the stones wear, the "slurry" so to speak gets on the sharpener, then you put your knife on the particles, and they scratch the blade.
Yes, you have to wipe down the blade and make sure you keep things clean.
Ahh ok now that makes 100% makes sense. So once the stones break in it won't scratch the blade?
the only way to remove the scratches is by sanding them out.....
Unfortunately, No. The nature of these stones is that they are made to wear like they do. Now, I am by no means an expert sharpener, and I know nothing of the KME system, aside from what I looked up. I am speaking only in regards to my edge pro. I assume the kme stones are the same.
Oh ok now that make sense.. So once the stones break ke in they won't scratch the blade?
