I'm about ready to pull the trigger on a new KME system with the new diamond stones. I don't have any diamond stones yet and this new line at KME looks attractive. What do you think? The sticking point I have is the base. I have a granite surface plate that is 6"x6"x2" that I'm thinking would make a pretty nice base. What I would like to do is adapt the granite piece to work like the standard KME base. In the pictures I've seen of the standard base it looks like a piece of 1/2" dia. steel that is drilled and tapped on one end so a bolt can be inserted up through the wood and screwed into the 1/2" piece. Is that right? Has anyone bought the stud from KME? If it's not available from KME, what did you use to make the base work for you? Your thoughts and experience would be most appreciated. Thanks...
Rgds,
Jeff
Rgds,
Jeff
