- Aug 13, 2014
I just got the deluxe kit in the mail and I have only sharpened two knives. Started with the 50 grit and worked my way up to the 1500 grit on their diamond series.
At this point after the 1500 diamond grit where should I go from there? Should I try the ceramic stones or buy the arkansas translucent? Even though the ceramic stones it comes with are lower grit, where they are ceramic shouldn't they polish and leave a less toothy edge from the diamonds?
I'm having the most trouble with the tip. I've rounded it several times, not terribly but enough to notice in light. That along with not being able to remove sharpie along a half inch of the tip after using the 50 grit diamond for quite a wile. I wasn't trying to get such a huge burr on the rest of the edge so I switched sides and focused on the tip. Then still couldn't get a burr from the other side, swapped it and did that process a couple more times. Still didn't get it as decent as the rest of the blade but it's not dull or have a burr on either side. Does this mean the knife needs to be clamped in a different position?
The only other sharpening process I've used a Dia-Sharp Course/Fine flat stone and then used the Sharpmaker rods Medium/Fine/Ultra Fine freehand and then stropped with DMT .5 Micron paste, so this is my first clamping system.
