- Nov 20, 2016
The KME sharpener works normally down to an edge angle of 17 or so degrees. If you flip the guide you can get, in my experience, down to 10 degrees or so depending on the blade and jaws used. I use that feature to put a relief angle of 12-17 degrees and then flip it around and do 17-22 degrees, depending on the blade. Works great.
I just got the thickness compensator. Works great in the normal assemble. But if I reverse it.... I cannot figure out how to make it work. Its probably not designed for that use?
Anybody doing this? Solution?
