- Jun 20, 2007
I am about to finally complete a KMG clone grinder. It has been a slow project with everything else that has been going on, in my life this past year or so.
Due to the fact that my shop is small and I have a bad back and moving things around lends itself to have as much of my shop on wheels as possible. It also it helps for me to have good daylight when possible to grind with my eyesight these days. My grinder is being set up on a cart with locking wheels to allow to accommodate for moving it around when necessary. I don't have a real good picture of the completed cart itself at this time and it is too late tonight to get one.
My grinder will be set up with a 10" wheel. I am trying to figure out when the 10" wheel is on the grinder what would be the best distance to set it up in relation to the edge of the work table?
In otherwords lets say when the sanding belt is on and properly tensioned what is the distance say "from center of the 10" wheel to the edge of the table"?
The grinder is going to be set up so the belt drops thru the table to the motor underneath the table. So once I cut the hole for the belt I will be limited to how much I can actually move the grinder itself!
Here are a few pics of the grinder set up trying to further explain what I am asking about! As you can see the cart will have to have hole cut in it to allow the belt to drop thru for the motor belt up.
Click thumbnails for larger view:
This is a photo looking down on the handle of the cart and where the grinder is setting now. I have removed the sanding belt to aid in seeing the grinder and wheel.
Can some of you who use a 10" wheel on a KMG or clone, with sanding belt installed and tensioned, measure from center of the wheel to the edge of your table to give me a good idea where to cut this hole in the cart for my belt to drop thru to the motor? My thought here is to get this grinder positoned right the first time to allow for the best work area, around a 10" wheel.
Or am I overthinking this! Is the amount a 10" wheel overhangs over the edge of the work table even a big issue?
