After thinking it over and over again I finally finished my list what I'm going to order from Rob.
I would really like you guys to comment on wheter there is something essential (or not so essential
) missing or if some of the parts I choose are not that neccesary at all or should be replaced (especially the small wheels, not that sure what size I'll need.
So here it is, my little list :
- 10" grinder package with the Caffrey platen instead of the normal one
- 2 spare tooling arms
- small wheel attachment
- 1" and 1/2" small wheels
- replacement grinding platen
- 1 extra workrest for use with the 10" wheel
- 2 single groove pulleys (one for the grinder, one for the motor) as I intent
to use my speed converter on the motor (not sure if the pulley for the
motor will fit the german motor shaft)
- 3 Drive belts (just in case one or two of them should fail in the future
That would be everything I would get from the US of A.
So what I would have to get here in Germany would be a 2 or 3 hp motor and something to mount the grinder and motor.
Now is anything wrong with my list, or do I have to regard something in particular concerning the pulleys, motor and other stuff that could cause problems over here in Germany?
One question that is floating around in my head for quite some time is, if everything (bolts, screws and so on) on the KMG and it's attachments can be handled with my tools, screwdrivers etc. with german measurements.
If not, that would be a pretty nice, little problem I would have to find a solution for.
Thanks a lot in advance for your answers. I really depend on you on this one, cause ordering something that I forgot will probably cost another fortune (and the KMG definitely reduces my amount of fortunes available
Regards Marcus
Regards Marcus
