Knife #17 - Recurve Hunter(?) from Hell... now camphor scented.
Erin Burke
KnifeMaker...ish
Good morning dudes. After much pain and suffering, I am offering up photos of knife #17.
Some Stats:
Length: 9-15/16"
Blade: 4-3/4" (Tip to Choil)
Steel: Differentially heat-treated 1095 (from Kelly Cupples) Flat-Ground
Handle: Stabilized Camphor Burl
Guard: 416ss w/ mild steel spacer
This knife may just have been my biggest PITA project to date. I had to re- heat-treat it twice. The first HT had a lousy hamon, but I ground and polished the edge too thin before I found that out. So when I did re-HT #1 I ended up with ripples in the edge. I did some reprofiling to get back to a straight edge and ended up with a recurve shape in the process. The third HT is the one that stuck.
After cleaning up the grinds from the final HT, I ended up Elvis-ing the grind on the back side of the blade (not shown in this photo). The edge also thins out more than I would have prefered at the belly of the recurve. Finally, I found out that one of my 400-grit trizact belts is frayed a bit and ended up adding some fine scratches just behind the edge bevel when I was sharpening. :mad: They are fairly visible if you zoom in.
This is the first time that I've tried a curved guard... it seems to have turned out OK.
The handle is stabilized camphor burl finished with tung oil. It is actually the second handle fitted to this knife. I pooched the first handle trying something new and ended up making it too thin. I didn't like the look or feel of the old handle, but just couldn't bring myself to start over. Fortunately, during one of the dry fits of the old handle, I forgot to add the guard spacer when hammering everything together and ended up with a several pieces of shattered camphor all over the shop. No choice but to start over. :thumbup: It's much nicer than before, but if you look close, you can see a small divot in the handle just behind the steel spacer. Grrrr.
I'll be happy to not have to look at this one for awhile. ;)
Erin
Really nice looking, I would say worth the effort! And think how much you learned in the process!
Steve
Potomac Forge
Thanks for the kind words guys. It occurs to me that much of my complaining and whining about making this knife would be better suited to the Shop Talk forum.:p
Steve, you're right about learning a few things. On thing I learned is that I'm ready to take a break from this type of knife - just for a bit - and turn out a few more folders and kitchen knives... anything that doesn't require a sheath. ;)
BTW, I pulled out the tape measure this morning and added some dimensions to the original post.
