- Sep 1, 2013
How do you guys clean your knives for long term storage, and what you use to coat them with?
I use renaissance wax and keep my most valuable knives in a pelican case. I also occasionally use acetone to clean them (Obviously only on the metal parts.) -- I think it's better to use something that completely evaporates when you're cleaning something that is supposed to go into long term storage. What are your thoughts on this?
I coat steel that will be used with Ballistol.
But I was also wondering, should steel have some access to oxygen? Or is it best to completely seal it to prevent rust? For example, there's a knob on the Pelican case that allows you to let some oxygen in. Should this be completely closed, or should it let some oxygen in?
I noticed that on one of my knives that I stored on a shelf, the areas where it contacted the glass it was sitting on had gotten discolored. My immediate assumption was that this was caused by the steel being completely deprived of oxygen. Is this in any way true?
"Rust only forms when conditions are right – when there is enough water and air. Iron will rust when the relative humidity in the air climbs above 50%, and steel rusts when the relative humidity reaches 80%. If your shop is unheated, iron and steel tools will also rust when the nights are cooler than the days"
http://workshopcompanion.com/Demos/...lassroom_files/Shop_Notes_Rust_Prevention.pdf
This makes a lot of sense. Even below 80%, if the humidity changes, steel will rust. Storing them in an environment that stays at a consistent humidity level is key.
