There is nothing easier than a nice coat of oil periodically applied to the blade.
What brand do you like of oil?
Generic mineral oil from your local drugstore....it's in with the laxatives.
For the most part, coatings are porous, if they weren't they could have the opposite effect and trap moisture between the steel and the coating accelerating rust formation. Do a search, this has been discussed at length and has been clarified by some knife manufaturers. As for duracoat and cerakote, google will probably provide some cursory information that you are looking for.
"BK1 ® COATING: BK1 coating is a matte black coating that provides excellent corrosion protection, which exceeds the ASTM-117 spec for saltwater while possessing higher scratch resistance.
BT2 ® COATING: A proprietary blade coating that is Xylan ® based to provide excellent corrosion resistance which exceeds the ASTM-117 spec for saltwater and increases overall surface lubricity."
3-in-1 oil. It's cheap, thick, and absorbs into steel nicely.What brand do you like of oil?
Mineral oil, especially if there is a chance you would use your knife for food processing or cooking. Same food rule applies for blade coatings in my book, and is one of several reasons I find blade coatings to be a liability. As a side note, if stealthiness is a priority then you (or anyone else) could put a vinegar patina on the blade, followed by mineral oil for protection and this should be more than enough to suppress any reflection from your knife that might be seen by game or hostiles.
