Knife Cutting Test
Hi Everyone. Is there a real good test for cutting ability? I discovered a good test of cutting ability by accident. I ran out of .080 weed whacker line and rewound it & started to cut it and the blade just danced on the stuff. I keep all my knives hair shaving sharp. The next knife from a custom maker did the same. Getting very frustrated I got my new Frosts Army knife & it zipped through it like butter. I also tried my opinel with a medium working edge & it cut it but not as easily as the Frosts & yes it will shave hair as well. To make a long story short, I was amazed at what some knives can do & others cannot. :grumpy:
My favourite tests are hard and soft wood shallow slices. (if the wood curls-good.) and shaving paper. Of course there is always the arm hair test.
This is why shaving hair is but one factor in how "sharp" a knife is. You can use even a coarse ~300 grit stone and get an edge that can pop hairs off your arm, and this will cut spectacularly on a large number of materials. Not all steels can handle an edge like this, as it tends to blunt very quickly as the micro-teeth don't have enough supporting material. I find I prefer semi-polished edges for most knives, around 1000-2000 grit, with higher grits for more specialized work, like woodcarving knives or "showoff" edges that excel at a particular cutting task but aren't really much good for anything else. At 1000 grit the edge will readily catch hairs above the arm and if I strop I can usually get them to cut off above the arm. There's also enough bite that it can cut solid materials like trimmer line with ease, as well as fiberous material.
First check that there's no wire bent over on one side or another.
Then, I just apply a bit of pressure with my thumb -carefully- back from the front edge at about 80 degrees. If it's "grabby" all along the edge, both sides equally, then I'll take a couple of slices off an 81/2 x 11 sheet of copy paper. If that's snag-free all along the edge, step four is to shave a bit of the arm hair, testing both sides of the blade. If all four conditions feel right, then she's ready for service.
pogo said:
..the blade just danced on the stuff. I keep all my knives hair shaving sharp. The next knife from a custom maker did the same.
The edge is too thick and/or obtuse, rip it down if you want to be able to cut that cord and similar materials better.
-Cliff
I don't know about anybody else but in my opinion I expect my new knife right out of the box to be able to pop hairs effortlessly off my arm. Most knives I have pruchased recently all do come this way. On the occassion it dose not shave or losses its ability after using it a couple of times I loose intrest in or feel that it may not be meet my expectations. I know this should and dose not make a bad knife but certianly spoils any excitement of getting a new knife. I was frustrated after years of buying knives to never get them back to the way it was when it was new. The only I found to really get what I was looking for was to buy a new knife. I sure this was partly an excuse to tell myself I just needed another knife. So I began a search to try and find someone who could teach me how to truly sharpen a knife. You would think this should be an easy task but I found it much harder than I ever expected. That is until I purchased a book from Razors edge which I read entirely the first day. After that I purchased a video from them as well as stones they make themselves. Today I can actually put an edge on just about anything and feel comfortable doing so an any knife. :eek:
