Knife grind using only files
I'm trying to make some knives here at work but only have an old bench grinder & some files to work with. How can I get some nice clean lines & an even grind with these tools? Looking for tips or tricks.
Thanks
S.
Thanks
S.
Are you grinding the old files into knives? if so
Make sure you have a Diamond grinder wheel dressing tool, and use it often. You'll need a bucket of water, and quench after every heavy pass. but try to use light passes instead. you'll be more precise with it. Use a paint stir stick to make your trial grinds, then move to steel. once mastered. Otherwise go to youtube and look up Green pete...
http://www.bladeforums.com/forums/showpost.php?p=9301974&postcount=14
Watch this video and stuff
Videos
Heat Treating Basics Video-downloadable
Right click and save this. Watch it once a day for 10 days and you will understand it much better.
http://www.archive.org/download/gov.ntis.ava08799vnb1/ava08799vnb1_512kb.mp4
Have you seen this ?
The Standard Reply to New Knifemakers v12
The answer to a 13 year old student is different than to a 40 year old engineer.
We may recommend a local supplier, or you may have a helpful neighbour; but that depends on where you are. We have members worldwide.
Fill out your profile with your location (Country and State at least), age, education, employment.
Look at the threads stickied at the top; many are expired, but not all.
The basic process in the simplest terms
Absolute Cheapskate Way to Start Making Knives-Printable PDF
Absolute Cheapskate Way to Start Making Knives-Website
Web Tutorials
Detailed instructions by Stacy E.Apelt
The Things I Advise New Knife Makers Against-Printable PDF
Handle Tutorial - Nick Wheeler-Website
http://www.engnath.com/manframe.htm
Books
A list of books and videos on the KnifeDogs Forum
http://www.knifedogs.com/showthread.php?t=5285
BladeForums - E-books or Google books
http://www.bladeforums.com/forums/showthread.php?t=603203
I like:
David Boye-Step by Step Knifemaking
Tim McCreight-Custom Knifemaking: 10 Projects from a Master Craftsman
These are clear, well organized, widely available and inexpensive too.
Knife Design:
On the Google books thread, you can find
Lloyd Harding drawings
and
the Loveless book with large variety of proven classic styles.
Google books thread
Forging Books:
Lorelei Sims-The Backyard Blacksmith
An excellent modern book with colour photos for forging in general - no knifemaking.
Jim Hrisoulas- has 3 books on forging knives. Check for the cheaper paperback editions.
The Complete Bladesmith: Forging Your Way to Perfection
The Pattern-Welded Blade: Artistry in Iron
The Master Bladesmith: Advanced Studies in Steel
Machine Shop Basics -Books:
Elementary Machine Shop Practice-Printable PDF
The Complete Practical Machinist-Printable -1885-PDF
It’s being reprinted now, you can get it for $20 ish
The $50 knife Shop
It confused me for a long time.
Forging is NOT necessary; you can just file and grind to create a knife (stock removal)
The goop quench is total Bull, commercial quench oils are available, even grocery store canola oil works much better.
Junkyard steels require skill and experience to identify the steel and heat treat it properly.
You can buy proper steel like 1084FG from Aldo very cheaply.
I like cable damascus, but that advanced project has no place in a beginner’s book.
The home built grinders are the best thing about this book, but there is now a huge amount of info for 2x72” belt grinders on the web, including free plans.
Videos
Many specific how to knifemaking videos are available, some are better than others.
The best overall Knifemaking video I have seen is
“Steve Johnson-Making a Sub-Hilt Fighter”
The best video on leather sheath making I have seen is
“Custom Knife Sheaths -Chuck Burrows - Wild Rose”
-(Paul Long has 2 new videos, his sheath work is fantastic. I hope the videos are too)
Green Pete's Free Video
Making a Mora bushcraft knife, stock removal, hand tools, neo tribal / unplugged heat treat.
"Green Pete" posted it free using torrent files.
Be sure to look at the other titles too.
Greenpete Knifemaking Basics-on TPB
You can see a list of videos and reviews at this rental company; some are worth buying, some renting…
They are slow to get new titles and wait times are measured in months,
http://smartflix.com/store/category/9/Knifemaking
Draw Filing Demonstration
YouTube video -Draw Filing-for a flat finish
Steel
The “welding steel” at Home Depot / Lowes… is useless for knives.
If you send out for heat treating, you can use O1, A2, D2, CM154, ATS34, s30v, 440C, plus many others.
If you heat treat yourself, find some 1070, 1080, 1084,
1084 FG sold by Aldo Bruno is formulated just for knifemaking.
You can find a list of suppliers here
http://www.bladeforums.com/forums/showthread.php?t=699736
Aldo is highly rated.
http://njsteelbaron.com/
Ph# 862-203-8160
Heat Treating
You can send blades out for heat treating at $10 or $15 per blade for perfect results, and avoid buying the equipment.
This PDF brochure gives a good overview
http://www.buckknives.com/resources/pdf/Paul_Bos_Brochure.pdf
http://www.petersheattreat.com/cutlery.html
http://www.texasknife.com/vcom/privacy.php#services
http://www.knifemaker.ca/ (Canadian)
http://www.bladeforums.com/forums/showpost.php?p=9143684&postcount=7
Grinder / Tools
Hand Tools
You can do it all by hand with files and abrasive cloth like the Green Pete video.
Photo of a nice bevel filing jig .
http://www.flemingknives.com/imagesPrime/FileStation/KPicB007.jpg
Entry Level Grinders
Many makers start with the Sears Craftsman 2x42 belt grinder.
http://www.sears.com/shc/s/p_10153_12605_00921513000P?prdNo=3
Commercial Production 2 x 72” Belt Grinders
http://www.prometheanknives.com/shop-techniques-3/grinders
Mapp arm – Grinder Toolrest
http://www.bladeforums.com/forums/showthread.php?t=466024
DIY 2 x 72” Belt Grinders
KMG Clone
Free Plans
http://www.dfoggknives.com/PDF/GrinderPlans.pdf
NWG No Weld Grinder
http://www.usaknifemaker.com/plans-for-the-no-weld-grinder-sander-nearly-50-pages-p-723.html
EERF Grinder (EERF =“Free” backwards)
Free plans
http://wilmontgrinders.com/EERFGrinder.aspx
http://blindhogg.com/blueprints.html
http://www.atlasknife.com
Buy the kit
http://polarbearforge.com/grinder_kit.html
Safety Equipment
I have a sign at my shop door, “Eyes, Ears, Fingers, Lungs” as a reminder to take off jewelry and put on my safety gear.
Respirators
The minimum I would consider are the 3M and North silicone half masks;
even better are the powered positive pressure fresh air systems.
http://www.bladeforums.com/forums/showthread.php?t=788837
http://www.bladeforums.com/forums/showthread.php?t=726309
V12 Edited dead links
Jason (Thanx Count!:thumbup::D)
I'd skip the bench grinder if you're looking for nice clean grinds. Slow and steady with a file. If you're using an old file for the knife steel, anneal it first.
I would do my profiling on the bench grinder and then file the bevels. Assuming you're starting with annealed steel. If you're not, then the same annealing advice applies.
First file the bevels, then draw file.
That is a good and controled way to get nice, straight lines
Thanks for that link!
I've been doing lots of reading & a little grinding. Pretty much Fubar'd my first knife but learned a lot of lessons & have started a second.
I'm still freehand filing but will build a filing jig for my next knife. I'm at work now & the welders keep telling me that the steel here is no good for knife making, but I am just using it to practice filing the bevels.
Supporting the knife on a piece of angle iron was the first trick I picked up! Also, leaving some extra metal at the tip while you are filing the bevel, then finish shaping the point when that is done. My first knifes tip got filed down to nothing...
I'm going to continue to profile knives with this welding steel so that I have hard patterns ready to go.
When I get home I am going to pick up some nice blanks so that I'm ready for a quality build next time.
S.
Edit: That tutorial is fantastic! Very comprehensive & has answered some other questions I've had
