- Nov 24, 1999
Here's a knife I made to donate to our troops. I'm sending it to the adopt a sniper program at www.adoptasniper.org . This is one of the best methods I've found for getting donations to the folks that need them. Generic addressed packages are hard for the military to handle with the volume of mail they're dealing with. Adopt a sniper and similar programs can send directly to the troops.
Its made of 1/4" thick O1, with black linen micarta scales, brass pins and thong hole.Blade is 6" long. Overall length is 11".
Here it was before being browned:
Here is now:
I used some browing solution I had left over from a muzzle loader and a few pairs of spurs. Took about 2 days and 5 coats before fitting the handle. This was difficult, I had to boil the blade to get the darker color which meant doing the handle section without the scales attached. I had to have the scales 99% finished so that I didn't have to do any grinding after attaching them. Once I had them epoxied and pinned on, I masked off the blade and tang edges and ground the pins smooth and completed finishing the scales. Then I had a little touch up work to do on the blade finish. I re-cleaned it with acetone and did a few more rounds with the browning solution. I'm pretty happy with how it came out. Browning hardened tool steel is a whole new ball game over gun barrels and spurs.
Here is the sheath:
The belt loop can be removed and put back on horizontally. Also has the slots for a web strap and lots of rivets to run cord through. Its far from the greatest, and I was hoping to give them more options. Things weren't going too well though.I decided I'd better stick with function instead of going for multifunction and getting disfunction
Still needs sharpened and I'm hoping to find a drawstring clamp to put on the sheath so they don't have to tie knots. The paracoard criss crossing the knife locks the sheath down as tight as you want depending on how tight you pull them, figured that way they could lock her in tight if they're jumping in from somewhere and could leave it loose for normal use. The sheath locks it up pretty well alone, you can hold it upside down and shake it fairly good, but it draws easily.
This was a lot fun. I have to get some paying knives down now, but I wouldn't rule out doing another. It was my first time doing a blade over 5", and first time using 1/4" stock, and first time browning it. I'm hoping to do them all again
So what do you guys think? Thanks for lookin
Here is now:
Here is the sheath:
