Hi guys,
I need a knife law interpreted as I do not know if it applies to my EDC; the Spydie PM2.
Here are the two pertinent passages:
( b ) any knife so designed or constructed so as to be used as a weapon that while the knife is held in one hand, the blade may be released by that hand;
(e) a flick knife, or a similar device of any material that has a blade folded or recessed into the handle that opens automatically by gravity or centrifugal force or if pressure is applied to a button, spring or device in or attached to the handle of the device;
http://www.police.qld.gov.au/programs/weaponsLicensing/indentify/categoryWeapons.htm
Category M weapons
Each of the following is a category M weapon
(a) any clothing, apparel, adornment, accessory or other thing
(i) designed to disguise any weapon or other cutting or piercing instrument capable of causing bodily harm; or
Examples
a bowen knife belt, a credit card knife
(ii) designed for use as a weapon or a cutting or piercing instrument capable of causing bodily harm;
(c) a ballistic knife that propels or releases a knife-like blade of any material by any means other than an explosive;
(d) a butterfly knife, a knife known as a balisong, a pantographic knife, or a similar device that consists of a single-edged or multi-edged blade or spike that fits within two handles attached to the blade or spike by transverse pivot pins or pantographic linkage and is capable of being opened by gravity or centrifugal force;
(f) a push knife, or a similar device designed as a weapon that consists of a single-edged or multi-edged blade or spike and allows the blade or spike to be supported by the palm of the hand so that stabbing blows or slashes can be inflicted by a punching or pushing action;
(g) a sheath knife, or a similar device of any material that has a sheath which withdraws into its handle by gravity or centrifugal force or if pressure is applied to a button, spring or device attached to or forming part of the sheath, handle or blade of the device;
(h) a star knife, or a similar device that consists of at least two angular points, blades or spikes, of any material, disposed outwardly about a central axis point and that are designed to spin around the central axis point in flight when thrown at a target;
(i) a trench knife, or a similar device that consists of a single-edged or multi-edged blade or spike of any material that is fitted with a handle made of any hard substance that is designed to be fitted over the knuckles of the hand of the user to protect the knuckles and increase the effect of a punch or blow;
(j) a riding crop that contains, conceals or disguises a knife, stiletto or any other single-edged or multi-edged blade or spike of any length or of any material;
(k) a walking stick or cane that contains, conceals or disguises a sword or any other single-edged or multi-edged blade, knife or spike of any length or of any material;
(l) any incendiary or inflammable device containing any substance capable of causing bodily harm or damage to property that is primarily designed for vegetation management;
(m) any pistol crossbow designed to be discharged by the use of one hand (that is not a toy pistol crossbow) that when discharged is capable of causing damage or injury to property or capable of causing bodily harm;
(n) any crossbow designed to be discharged by the use of two hands that, when discharged, is capable of causing damage or injury to property or capable of causing bodily harm;
(o) a chinese throwing iron that is a hard non-flexible plate having three or more radiating points with one or more sharp edges in the shape of a polygon, trefoil, cross, star, diamond or geometric shape and constructed or designed to be thrown as a weapon;
(p) a flail or similar device constructed and designed as a weapon consisting of in part a striking head and which, if used offensively against a person, is capable of causing bodily harm;
(q) a device known as a manrikiguisari or kusari, consisting of a length of rope, cord, wire or chain fastened at each end to a geometrically shaped weight or handgrip and constructed or designed for use as a weapon;
(r) a device known as a knuckleduster or any device made or adapted for use as a knuckleduster and which, if used offensively against a person, is capable of causing bodily harm;
(s) a weighted glove designed or constructed to be used as a weapon;
(t) a mace or any similar article (other than a ceremonial mace made for and used solely as a symbol of authority on ceremonial occasions);
(u) any device, not a toy, constructed or designed as a telescopic baton, the extension of which is actuated by the operation of a mechanical trigger.
