Hi, I'm making a knife in school and i want to put red liners in the handle, what materials could i use for them? Keep in mind im a high school student and i dont have access to anything "fancy" like G10. Just looking for suggestions, thanks
well if it needs to be something you have access to you'll need to check what's available locally, in hardware or industrial supply stores. Rubber maybe? linoleum? Some thin plastic that's not too brittle? Or maybe dye & polycoat some thin hard wood?
Just don't use anything that can absorb moisture or it will swell/warp over time.
if you have enough time, I'd suggest going to Jantz supply or Texas Knifemakers supply websites and buying/ordering red fiber liner material. It is pretty cheap and is specifically designed for it. Comes in all colors.
What is your timetable for the knife? Red vulcanized fiber, which is for making handle liners, always looks good. I may have a sheet lying around that I could send you. This is what they look like:
You can look for just about any flat plastic type material. Look at thrift stores for lids that are flat or try craft stores for small sheets of material. Your best bet will always be a direct knifemaker supplier like Jantz or Alpha Knife Supply but if you cannot do that be creative and look at what is around you.
