- Mar 16, 2014
Looking for a good knife lubricant, can't decide on one. Upon researching I found that Tuff Glide was supposedly not safe for food prep, but would it really matter if I was just using it on my pivot?
I would say it doesn't really matter if you are only using it on the pivot.
I use Nano-Oil on my pivots and either food-grade mineral oil or Frog Lube on my blades.
I also vote for Nano-Oil, but I have used Benchmade Blue Lube and it works pretty well. Keep in mind, you don't need any oil on a blade that is made of stainless steel. So for example, S30V, S35VN, 154-CM, etc are stain resistant and can go for days without being maintained. Steels like 1095, M4, 1055, 52100, etc (carbon steels) need to have a bit more attention or they will develop surface corrosion.
Mainy going to be useing for my pivot. So should I go with blue?
Nano-oil is the way to go for the pivot. I use Tuff-Glide or Eezox strictly for rust prevention on the blade, they don't seem to work as well for lubrication. For spring assisted blades I use a generic white lithium grease with teflon for lubing the spring.
I personally strongly prefer Eezox over the Blue Lube as I think Eezox Knife Care does the same functions of the Blue Lube, but better, for less money, with less gunk buildup over usage, and with only one product being used. I don't find the Blue Lube to last notably long, I don't think it retains-->lubricates well in the areas with the most friction, and I find it to be prone to "oil migration". As a general rule, it is more expensive than Eezox, which I consider to be a better product.
The earlier Blue Lube was more or less Militec-1, which is a terrible product compared to the many better oils on the market. The newer lube is something different and much better, but I still strongly prefer Eezox over it. As others have noted, it's still not a top-pick for pivots and I try not to use it in that application. Something like Nano oil, Frog Lube, RIG, Extreme Fluoro, a fluoropolymer, etc. is arguably more appropriate for that specific application. I think those types of lubricants are better at reducing actual wear, which is the primary purpose of lubricating the pivot.
For corrosion resistance, I do not think any common product compares to Eezox, and my own usage caused me to switch over from TuffGlide as the Eeezox just did a better job. Despite being a true dry lube, I find it gives reasonably good lubrication. The below tests also shows how Eezox remains on metal over extended time durations and environmental exposure to humidity/water, as well as how few of lubricants actually do this. Many people are often surprised by the results.
http://www.thegunzone.com/rust.html
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1236786
http://www.theopenrange.net/forum/index.php?topic=5457.0
http://www.ctmuzzleloaders.com/ctml_experiments/corrosion/corrosion2.html
It's not that crucial. I won't fall for the nano-diamond fad, and use BM bluelube, or some tri-flow. Nylatron washers don't need lube, Bronze washers may or may not, but a drop doesn't hurt.
