I bought a sanrenmu b4 710 off ebay for $6.50.. Guess what. The blade is perfectly centered the lockup is like its a fixed blade and its smooth as butter. The whole knife has the feel of something i would pay around 100$ for. In terms of how sharp the blade is, Sanrenmu knives are iffy. some come razor sharp some come a little duller. Mine had a good working edge on it. i used it to open a few boxes i got in the mail with the factory edge. Sometimes you get blades that you can shave with. But hey for 6 bucks its amazing. Since were on the subject of how sharp the blade is i will point out the bevels are not 100% even. BUT, Its hard to notice. That being said my $160 benchmade griptilian with an s30v blade was the same way. most factory edges are. If your a serious knife collector you have a means to sharpen your blades anyway. The whole knife is held together with hex bits so almost anyone can take it apart easily. The pocket clip is tip down right hand carry only but for me that's fine. Getting a blade and opening it is just as fast either tip up or tip down for me. The pocket clip is very tight but that's ok because its against smooth metal that wont wear down your pocket. When you get the knife be prepared to lube it up yourself because it comes to you dry. In conclusion i am extremely satisfied with the knife for its low cost. Its better then allot of $60 knives i have seen and i can easily recommend them to anyone who knows how to sharpen a knife and has the knowledge for basic knife maintenance.
Yes i know this post is all over the place because i was just writing down stuff as i thought of it.
Thanks for taking the time to read and i hope i helped someone with this post =)
