- Oct 27, 2009
Not sure if this is the correct forum to post this in and if it's not, I apologize in advance.
So I'm planning modding my Martindale Bolo machete into a big Bowie knife. I've never changed the geometry of a blade like this before so this is new to me. I was originally planning to do the rough shaping of the blade with an angle grinder and then use hand files to do the rest (don't have a belt sander atm) but I know using a power grinder can run the risk of warping the blade's heat treat if not careful. What are some of the ways you guys use to keep your blades cool while grinding and are there ways to tell if your blade is starting to get too hot? Also would a grinding disc or cut-off disc be more efficient at removing steel? Admittedly I don't have much experience using an angle grinder in the first place. Since I'm not super familiar with this particular power tool, should I just forgo the grinder and stick with a hacksaw and hand files to shape my knife? I know that will take a fair bit longer but ruining the heat treat on my knife is my biggest concern at the moment. Are their any other tools (besides a belt sander) I should consider for shaping the blade? Any tools you guys recommend for this sort of work period?
While shaping the blade is my current objective, I plan to add some antler scales and a brass guard at some point. I would like to do a thinner style "S" guard (about 2mm thick and 4" in length) but can't seem to find a pre-made one I like so I might take a stab at making my own. Would I need to heat up the brass to bend the edges to give it that S shape or would 2mm brass be thin enough to be bent in a vise or something without heating it?
Sorry this was a long post. Like I stated earlier I'm totally new to this level of knife modding so any advice or tips you guys can give, is very much appreciated.
