- Mar 25, 2019
With so many oils on the market, how do you know which is best at protecting your knife from rust? I decided to do a casual experiment to see how each of my knife oils would perform with regard to rust prevention. See the attached photo of the final results after 3 weeks. Details below...
Test:
I used box cutter blades. They were hung from thread and dipped in a salt solution twice a day for 3 weeks.
Rating:
1st: Breakfree CLR - ZERO rust
2nd: Speed X - Very slight rust as indicated by discoloration at salt buildup
3rd: Corrosion X - Slight rust at base
4th: Nano Oil 10wt - Rust at base and slight rust on face of steel
5th Rem Oil - Rust at base and face of steel
6th Super Lube - Rust at base and face of steel
7th Militec - Severe rust at base and face of steel (not heated)
The blade at the bottom of the photo is the control.
Photo:
https://drive.google.com/open?id=1zclCUftfGtpH97fyEorvcSyKKHL36L6W
Test:
Rating:
Photo:
