Hello,
I always wanted to do some knifes by myself and recently I started. I slowly learned, how to do basic shape, grind edges on belt grinder.
I use for my knifes steel 12C27 and I am satisfied with this steel. Currently, I am struggling with final polishing to mirror. I would like to ask more experienced knife-makes for advice.
How to do that mirror shine?
My steps:
1.) Grinding with belt grinder in jig using cubitron belt grit 60 - rough shape
2.) Still in jig using Trizact belt with renctagles grit 220
3.) SStill in jig using Trizact belt with renctagles grit 400
4.) Still in jig using Trizact belt with renctagles grit 800
5.) Hardening
6.) Surface is already not so bad and my thinking to finish was:
- Use belt grinder again with belts to grit 1000 and finish again in belt grinder with felt belt and paste chromax an as last felt belt with paste titan extra
- Result is not good, hold knife in hand in exact angle using tin belt grit 1000 is difficult to me and surface is not homogenous. Polishing paste does not stick to felt belt much, definitely I did not get mirror shine
- I tried also hand grinder (something like dremel) with 3 leather discs and paste instead of belt grinder and I am also not happy with result, there are still scratches, which I am not able to get rid of.
- I tried to do that just with sand paper, bought big set from grit 800 to 7000. Took a lot of work but at the end, seems to me, that there are still visible scratches from first 800 grit sand paper
I invested to felt belts to belt grinder, than to leather discs and big set of sandpapers. Definitely, I am learning and probably not do everything good, but which way give me best result?
Also, I am little-bit lost with amount of polishing disc types and paste types. Please can you advice which equipment to buy to get good result?
Thx.
My steps:
5.) Hardening
Thx.
