- Sep 19, 2017
I'm a newbie and I'm not particularly coordinated. Recently, I was trying to reassemble a knife, and I found that I just didn't have enough hands. I needed one hand to hold together a scale, pivot, and the liner lock; a second hand to hold the other scale; and a third hand to screw in all of the screws and the other side of the pivot. Every time I would get close to reassembling the knife, something would fall out of place due to the lockbar tension, and I would have to start all over again.
I couldn't use a clamp, because that would get in the way of reassembly. It finally dawned on me to wrap up one scale and the liner lock in a rubber band, which allowed me to lay down that portion of the knife. Then I could lay down the other scale on top of it, and the lockbar, under tension from the rubber band, wouldn't push away the other scale. Finally, I could put in the screws.
When it was all over, all I had to do was take another knife, and cut away the rubber band, and now the knife was good to go.
