Gryffin said:
longbeachguy, keep in mind that Sal Glesser himself has stated that a little play is to be expected in Spyderco's lockback knives. In my experience, it's more common in the FRN ones. It doesn't make the knife unsafe to use or anything, so rather than end up with a knife that's a b*tch to open, you might want to just leave it be unless the play is excessive, in which case I'd recommend letting Spyderco take care of it.
Thanks you guys. I have about ten Spydercos, mostly FRN, in fact all except for my Kiwi. I certainly don't mind a little blade play, but this Native had a lot. I'm sure it wouldn't affect the knives performance, it's just annoying. I completely acknowledge that.
Well I changed my mind and decided to try to work on this knife myself. I then discovered that "old school razorblades" are hard to find. So hard in fact that I was unable to find them at all. Since I couldn't find a suitable alternative, I tried to just tap the pivot without using any spacer at all. Since nothing happened when I tapped it I hit it progressively harder until I was worried I was going to hurt the knife, but I didn't accomplish anything with the pin except scratch it up.
So, I threw caution to the wind and stuck it in a vise to compress the pin and the joint, thinking that I may bend the pin instead of compress the ends, which would ruin the knife, but what the hey. Anyway, it seems to have worked. There's still a tad bit of play, but completely within the acceptable range. Also, the action is still smooth and not overly stiff.
I'd be interested to know anyone's thoughts as to why this worked and tapping, hitting and even whacking the pin with hammer and punch didn't.
Am I stupid or lucky or both?
