- Sep 5, 2013
Hey guys, I've been reading this forum for a while (and learned a LOT) but have finally decided to make it official and register/post. I have a question for all you knife-makers out there. I've made a knife out of 01 steel and just finished the rough outline of the handle made of Olive wood. I had both scales loosely pinned to the knife overnight and was going to start sanding/contouring the handle this morning but when I pulled the scales apart the knife had started to rust where the wood was touching the metal. I know Olive wood is naturally oily and that 01 steel will rust if not properly taken care of but is there anything I can do so that I can continue to use this handle and keep the metal underneath it from rusting away? After I get the handle sanded and finished I plan on using a waterproof epoxy and peen two brass pins as well. Will the waterproof epoxy act as a barrier between the oily wood and metal? What do you all think I should do? Thanks for all your help!
