Knife Scanning FAQ
One problem I often see posted about is scanning knives and getting good results. Some of you are old hands at it and have no problems getting beautiful scans of your knives, but many of the folks here are having trouble. So, here's some general information that may help out those of you who are having problems.
Firstly, I always scan knives (or any three dimensional object) by laying the knife directly on the glass of the scanner and covering it with a dark, somewhat opaque cloth (a dark sweatshirt works quite well) and turning off the lights in the room. If you find this causes a lot of shadow in the image, try tucking the cloth in around the knife. Using only the lid of the scanner doesn't make for a good light seal. And light leaking into the scan from outside sources can destroy the quality of the image, making it appear "washed out" or "blurry."
Also, I usually scan at 300dpi. It takes a little longer, but the results are usually worth it. Not to mention, when you sharpen the image up in your image-editing software, there's less work for the software to do and therefore less chance of it making the image look "rough."
After scanning, you're very likely going to want to bring the size of the image down. Doing this often results in slight blurring of the image, so you'll also want to sharpen it up after sizing. Depending upon the software you're using, the default settings on the "sharpen" feature may work perfectly. But if not, look for an option that reads "Sharpen hard edges only" or something similar and try using that.
Chances are you'll have to play around with the settings on your software to get the desired effect. Just remember to hit the "Undo" button (if there's no button, you should find it under the "edit" menu) to get back to the original before trying something different.
Comments from others that have had good luck with scanning knives are more than welcome in this thread. Particularly software-specific tips.
Here's a link to a pic I've scanned using the exact process outlined above:
www.workingwebdesign.com/knives
Hope this helps.
Regards -- Shades
Thanks Shades, im gonna study hard.
The problem I'm having is that anything that's not touching the screen is blurry. Any way to fix it?
Tonk
Only one way to fix that is to get a new really good scanner.
Other knives need to use a digital camera.
We use both at WOW.
Best Regards,
Mike Turber
BladeForums Site Owner and Administrator
Do it! Do it right! Do it right NOW!
www.wowinc.com
Ok thats great! Now someone tell what is a good scanner,am new to computers,and I would like something that would give me a clear picture.
Jack, I've had good experiences with scanners made by UMAX. Good quality, average price. Best Buy sells the 2000U (USB connection) for around a c-note. I'm sure you can find them for even less online too. Right now I'm using a old low end 30-bit scanner from Storm Technology, slow as hell but gives good results. A good scanner doesn't necessarily have to cost a lot, but it's just like any other piece of computer equipment, some products in a given price range are better than others.
Regards -- Shades
The deed is everything, the glory nothing.
Shades thanks for the reply.The question is do I spend the c note on another knife or get the scanner?
Hey Shades,
That scan came out well.
Thanks for the tips.
Regards,
Ron Knight
Yeah I'm crazy, but what do you want me to do about it
Heh heh, that's for you to decide Jack. I do web design full time, so spending money (tax deductible anyway) on computer equipment is a given.
And Rich, as always, more than happy to be of assistance.
Please feel free to ask me about anything I haven't covered already (of which I'm sure there's plenty). I'll answer if I can, and if I can't, chances are good that somebody else can.
Regards -- Shades
Shades,
After it's scanned what are the steps to getting it linked to a Post?
I've been trying your suggestions, they work very well, but where do I go from here?
Thanks in advance,
PhilL
P.S. Please keep it as simple as you can, I'm not that strong on the computer!
Phil, if you've got the pic online somewhere, just type the exact address in your post. It'll automatically link.
If you don't have it online, I'm afraid I can't help you, as I've never tried to put a picture directly into a post here. I'm sure one of our fellow forumites can tell you how to do that though.
Glad I was able to help with the scanning!
Regards -- Shades
