Excellent response.
Horizontal push cut is no easy task for sure.
I also agree with you about hair whittling edge being mostly a circus trick for heavy use knife.
(Cool factor is, however, undeniable.)
The newspaper cuts are, though, still a bit of mystery to me.
I do it using phone books (which I found to be harder than most newspapers),
but I'm not sure if it's any better than using finger or thumb pad;
again in the case of heavier use knives.
On one hand, if you allow even slight sawing motion,
then you can get a knife to cut them with 400 grit stone and couple swipes on the leather.
So it's easy to achieve off the stone.
On the other hand, if you get a few tiny little chips, then it'll fail the test.
But in reality, tiny chips don't affect the cutting performance at all.
So it's easy to achieve, it's easy to fail, and many times don't correlate with real performance.
Well, I babbled for no reason.
I'm just trying to square things in my head by typing them out.
Anyways thanks for the vid, I enjoy and learn from them.
@28:47 Cheers!
But let's make sure there is no confusion:
The goal of each sharpening (angle, refinement, grit-progression) depends on the knife, the steel, and the POU. Why no hair-whittling demonstration? Well, you'll find that a hair-whittling edge is pointless for any purpose but hair-whittling, and that level of refinement has a very short effective life and can even be detrimental depending on the knife and the POU. I think about each sharpening carefully because it should have a goal: what is this knife, what is it supposed to be used for, and who is using it? This particular knife (a beat-to-hell, $10--probably--Chinese Santoku), it's steel, it's intended use, and it's owner all make for a sharpening that doesn't involve busting out the diamond sprays and balsa. Additionally, I would ask you if holding the knife horizontally (parallel to floor) and push cutting all over the edge on newsprint is really all that easy? I've been sharpening for a while, and you could have fooled me...
