DMT diamond stones are hard to beat. Mark the edge with a Sharpie so you can see what you are doing.
+1 for DMT. Wear resistant steels like S30V can be sharpened on normal stones, but it takes a lot more time and patience.
I would get something really coarse in DMT and then get various other grits in non-DTM normal stones[/QUO
do you think a smith's quick sharpener would work okay? Jw, cause I have one of those that does some softer metals pretty well.
I just got one as well. I'm no expert in sharpening but I think it might be easier with a diamond rod or similar sharpening steel because of the recurve, seems difficult to lay it on a stone.
Do you mean the carbide V style ones where you pull through?
If so, the answer is no. I wouldn't use anything like that on a knife that is even worth more than 40 bucks, let alone your ZT.
I don't know what your sharpening level is, but if you aren't too sure about your ability, you should pick up the spyderco sharpmaker. Forgot that it had a recurve too, which makes it more challenging
Get a spyderco sharpmaker and the recurve will be no problem. If you want you can purchase diamond rods for the sharpmaker as well as ultrafine rods to get an even sharper edge. You'll be able to sharpen your 0350 just fine on the sharpmaker with just the stock medium and fine rods, just make sure you touch up the edge before it really gets dull and you'll have no problem.
+1 on that. I use an Edgepro now, which costs a lot more than a Sharpmaker, but when I got into the hobby the Sharpmaker was the system I used. I got by just fine with it, and could make my knives almost as sharp as I can now. I kept the Sharpmaker because it's a much more versatile and portable system, still my go-to for serrated edges.
I'm at about this stage myself. I used to use wetstones as a kid, but I never had much luck. Man, have things changed after that sharpmaker. I use a strop too, nothing fancy, but it came with the BarkRiver grit sticks to rub into each side. I have noticed that it takes longer for my S30v to take an improved edge faster than my A2 convex (on the strop). I'm at about the smoothly cutting phone book paper level of sharpening.+1 on the extra rods. It only comes with medium and fine. The fine is great, but trying to apex for the first time on the medium rods will frustrate you. The diamond rods are a must, if you have no other means of reprofiling. The ultrafine rods will give you an amazing edge.
