I used to try to polish every edge I had at a lower-than-factory angle. I actually got pretty good at it, but I found the same thing happening to me that you've mentioned. Those edges were pretty to look at, but they took time to achieve, more time to maintain, and I actually got better cutting results from less refined edges in a lot of my normal cutting chores. I've backed off a lot on the sharpening I do. A lot of it comes from loaded strops now instead of sharpening stones since I clean and "restore" my edges after each use.
Most likely, what you're getting from the medium grit stone with Buck's 420HC and the blade profile and edge angles they use is a pretty sharp general purpose edge that has very fine micro-serrations from the stone. This is actually a pretty good edge for a wide range of general cutting tasks. Most people don't shave with their knives, so while shaving hair is impressive, a highly polished hair popping edge isn't always the best edge for the task(s) at hand. Buck does a pretty good job of setting the edge angles on their folders to be useful for the average knife user's needs and maintenance skills. If you haven't changed them much during sharpening, this pattern you're getting should work well for you with the 110.
If you want to try out different sharpening techniques and mediums to see what kind of edge you get, then focus on knifenut1013's post and choose the angle and sharpening kit that will have the type of medium and the grit sizes that you need to achieve your desired edge.
