Had couple old planer blades wanted to see if could make a knife so did a slow stock removal to prevent ruining the temper.
All I know is it’s a high speed tool steel and seems to have a high Rockwell.
No steel cutting blade or drill bit I currently have touches it. Took a while to cut to length with a steel cutting wheel.
Is a diamond bit gonna be only way I can drill holes for scales?
Would using polyurethane and just glue scales on work?
Took a keen edge and held up to throwing plus cutting/chopping on aluminum.
Side note. Don’t laugh. This was All free hand with an angle grinder and 3in carpenters belt sander,.
Convex grind with a 34 inclusive microbevel turned out to be cut pretty good
