Knife storage, humidity
Hey all I reside in a small two bedroom apartment and have my collection in a tool box with silica gel packets inside. We are getting a heater installed that will be on a lot as it is winter here, do I need to be worried that my collection could rust due to the humidity from the heater? Any tips would be appreciated. Regards Hermit.
I would think that the heater would decrease the humidity in your apartment, not increase it.
That.^
(Assuming it's an electric heater) I wouldn't worry about the heater itself, creating or making worse any issues with humidity. That's not to say humidity is guaranteed to be low enough to be safe for your knives, in using the heater. But the heater alone shouldn't create any greater risk.
If the apartment isn't otherwise environmentally controlled (sealed windows, etc), the humidity could still be an issue, depending on how high it might normally be in your location. If the relative humidity indoors is ~ 40% - 50% or higher, there may still be some risk for rusting. Probably don't have much to worry about though, if the relative humdity is 30% or lower, indoors.
I lived in Texas for 20 years, and the typical humidity indoors at my house was usually somewhere between 40% - 60%, depending on the season and whether I was running the A/C (which pulls moisture from the air and therefore lowers the humidity indoors). That was a little bit marginal for risk of rusting with some of my knives, which could develop some spots in those conditions. Since then, I've moved back to my home state of New Mexico, where it's typically much, much drier. Indoor humidity levels are rarely above 30% - 40% at all, and most of the time, much lower than that. Almost no risk for rusting, for my knives, in that environment. That's my frame of reference, in estimating what's probably 'safe' for my knives.
Thanks for the info very informative, I live in a dry area so I should be fine. Though to be safe I’ll tuff glide my blades I’m wandering if I should use it on my S35vn blades?
Certainly can't hurt. Your S35VN blades are 'stainless' in the technical sense. With that, and a dry environment for storing them, they should be OK anyway. But oiling or treating them with something could also help prevent issues created when you use or carry them in-pocket, with sweating on a hot day, etc. Many have had issues with sweat-induced rust-spotting on S30V, for example, which is roughly similar in composition. Over time, you'll figure out what it needs, if anything at all.
