- Aug 17, 2000
In my last post I put a cheap folder through some tests until it broke in my quest to learn what a knife can do. I think it is vital to gain this knowledge if one thinks of a knife as a survival tool. This time I tested two fixed blades, one of them broke.
The one that broke was a $35 Muelay knife made in Spain that I got as a gift. It had a 6 blade marked inox. The handle was beefy made of metal and plastic. The knife that survived was a Cold Steel Recon Tanto.
Like the tests of the cheap folder I cut apart several empty metal food cans with both fixed blades until I got bored. I then went to the old metal garbage can, stabbed 6 holes with each, and twisted the knives 360 degrees enlarging the holes. That got boring. I then pried 3 cabinet doors off the frames, with each knife, ripping the screws out.
The Recon Tanto had some slight scratches on the black coating but was still shaving sharp. The Muelay blade was dull and it developed some play where the blade meets the handle.
I decided a good practical test would be to see how much weight a blade could support. I inserted the blade of the recon tanto (blade down) into an open metal pipe (2 diameter) that is used to hold my weights. I used the cold steel as a step and it easily held my 210 pounds, I even bounced up and down. The sharp part of the blade was not damaged and I shaved some hair off my arm.
I tried the exact test with the Muelay. It snapped where the blade meets the handle. Upon examination I found that it was not a full tang. The handle gives you the intentional false impression that it was a full tang.
I learned first hand that I can depend on my CS fixed blade knifes to do certain things and not to trust cheap knifes made in other counties. You get what you pay for. I just ordered some swamp rat knives. I wonder how they will hold up.
