When you need to use your knife often, what system do you like to use?
If the task is clean... say you undo a lot of packages.... then you can have a retractable box cutter in your pocket and your operation can be quick. Grabbing the knife, pushing the blade forward, retracting the blade and slipping it back into the pocket will soon become automatic.
When I go hunting with a rifle, I'm only likely to use my knife occasionally. If I have to gut or skin something then my sheath knife only needs to go out of and back into the sheath a couple of times. And generally I can wipe it clean before returning it to the sheath.
If I have a lot of tasks to do, then it is possible I will get frustrated trying to line up my knife with my leather sheath every time so I don't cut the sheath or miss it altogether. And if I'm doing a lot of messy jobs, then it is likely I will get a build-up of gunk in the sheath.
When I was setting a lot of traps, I needed to use a knife frequently to cut support twigs, to remove obstructions, spread lure etc etc. Then, when I was checking the traps I might need to stop and skin several animals.
I found that a one-hand opening folder was very convenient. It is a natural movement to put my hand in my pocket to pull out the knife or to return it. However if I was wearing a raincoat I'd have to lift the coat to get to my pocket. And my pocket soon became fairly smelly.
In fish and meat processing plants, knives are often carried in a plastic scabbard which is easily cleaned. However the scabbards that I'd seen did not hold a knife securely for hiking, they were noisy and just too bulky.
I came up with the solution illustrated below. The knife has a tapered handle and it sits snugly and securely in the sheath which is made from low density polyethylene water pipe (which is softer than some pipe).
I hung the 'sheath' from a simple plaited cord belt. The cord has an eye at one end, and a hook fitted on a prussik loop at the other. The prussik loop can be slid along the cord to adjust the belt.
I found this to be a very convenient rig that was quick to use and easy to keep clean. It doesn't look like something you'd see on a knife collectors forum, but it is a practical solution.... and something I could quickly make myself. The knife blade, I think, was a sawmill bandsaw blade in a past life. The scales were made from worn plastic scrapers that once were part of a big batter mixing machine. The blade is around 2.7 inches long.
When setting or checking traps I would generally have another blade or two with me of course. For a while I carried a hatchet... then a few different khukuris..... and sometimes a machete. Sometimes I'd carry my hollow-handled Cold Steel Bushman and the 'walking stick' it fitted on in case something I had to deal with was too big or out of reach (sometimes a snared possum would have enough tether cord to climb a tree to where I couldn't grab him).
I'd be interested to learn what other folks do for carrying a knife that is used often. Thanks in advance.... best wishes... Coote.
