If you want to reduce the texture of your blade scales, work it over with some high grit wet/dry sandpaper. I'd start with at least 600 grit.
This is an inherent problem with carrying the same EDC every day. Not that carrying the same knife every day is a bad thing but this is a possible problem when you do. I mix my EDC rotation up quite a bit and often and I have never had a hole problem. The top seam of my pocket sure takes a beating from the clips though.
If you are going to sand around on G10 please be careful. Use a respirator or sand it under water that stuff is pretty carcinogenic. FWIW
sounds like you need some tactical britches.
Kevlar trousers will help.
What he said. No matter how smooth, if you carry the same thing, it'll wear on pants. Think of all the Copenahgen can rings you've seen on back pockets.
