knife with blade length under 3"
CH
I need a knife for both defensive use as well as general utility, and it must have a blade length under three inches(Illinois :rolleyes: ).
No liner locks, please :) .
So far I'm considering a Benchmade Mini-Griptilian and a 705, as well as a Camillus EDC although I'm not too sure about the blade length on that one.
Thanks for the help!
Clay
I don't know if your state considers "the blade" to be all of the exposed metal from the handle or just the edge, but the Spyderco Native might be just what you need.
Good luck,
Allen.
You might want to try out a Spyderco Lil' Temperance. It has a VERY strong blade that's just a hair under 3 inches, Maybe something like 2.98 inches of extremely stout blade in two different styles. It features an awsome compression lock that definatly inspires confidence, considering it's part of Spydercos Martial Blade Craft lineup and is rated at over 200 pounds per inch of blade. If price is an issue I would suggest a Spyderco Native with a stainless hangle. On the stainless model you give up some blade steel quality but the built is much stronger.
Just something to consider.
Spyderco Gunting (2 7/8" Blade) with Skunkworks Kydex Holster. Spyderco factory specs have Lil'Temperance right at 3". For EDC, the Lil'Temperance is great; however, it does not compley with the IL law.
Clay,
I have the CUDA EDC 154CM blade and carry it almost every day. With a ruler the following in the best I can tell:
cutting edge is 2 7/8 in.
the way the handle is shaped the blade is 2 15/16 in. from blade tip to the handle.
opened the knife is 6 3/4 in.
closed it is 3 7/8 in.
Hope this helps.
Dean
i have a mini griptilian and i cant see how you could possibly go wrong with one, great knife at a reasonable price imo.
hth
Gunting. I think itsa great knife, whether you buy into all the Gunting techniques or not.
I have both the Griptilian and a newly acquired 705. Both are tremendous knives and the Axis lock is a gem. Flip a coin between the two, enjoy your choice and don't second guess yourself. Either makes a great EDC blade. If maximum rust resistance is desirable, the edge goes to the Griptilian; otherwise, I prefer the 705 just because of the feel of the G10 scales.
Mike
I met Will Fennel last weekend and he said the EDC is 2.95". It has a nice recurve for cutting whatever you want and comes razor sharp. The knife is very thin in the pocket and the handle allows a comfortable, but positive grip (wet and dry). Can't go wrong with this one. The mini griptilian is pretty thick.
No knock on Benchmade though - I own them too.
The small Sebenza is an incredible knife with a blade that is a hair under three inches. I love mine!
Camillus EDC.
If you're willing/able to spend the money, the small Sebenza.
Paul
Wow, thanks guys for all the great replies! I'm getting a full size Griptilian in a trade so I'll see if I like that design. I've had a 710 and found it to be outstanding. The 705 may be the way to go.
Thanks Paul for the measurements :) . I'm not sure if I can get used to tip down carry, but I think I'll get a Camillus EDC and give it a go.
I actually live in Arkansas but the in-laws live in the Land of Lincoln so I'm looking for something that complies with the laws there. Mainly though I don't want to spend a fortune as I only go up there once or twice a year. It's the only place I go where I have those particular restrictions.
As to linerlocks, it is just my opinion mind you, but I've owned a dozen or so from all of the big names and I've personally found them a bit tempermental, so to speak. They seem to require more from the manufacturer, which means it's easier to get a lemon vs. a lockback or Axis type lock, and they tend to require adjustment more often than not. Again this is just my opinion :) .
Thanks again,
Clay
