Again, keep in mind my postst are not intended to discourage, but to encourage you onto a more satisfying path.
the most common 2 steels used in swords coming from India in the last 20 years is 420J and 5160-ish old leaf spring. Even the ones touting 440 stainless fail to mention it is NOT 440C (the high carbon version of the 440 series)
420J is a stainless steel, highly rust resistant, and will harden to the mid to high 50's in a heat treat. It isn't great on toughness at that hardness, and once tempered down, doesnt hold an edge that well, so most knifemakers shy away from it.
5160 is tough, holds a decent edge, but most knives from over there spent a lifetime already holding up a truck. This tends to cause microfractures that can cause unexpected failure.
keep in mind that even the least desirable of high carbon steels will get hard enough to skate a file, or prevent cutting with a hacksaw.
Anyone who knows me will tell you I have no problem making something from old junk, Springs, files, RR spikes... all fair game. But it is important to make sure you have SOME Idea of what steel you are dealing with. For a beginner, I'd say have fun playing with your sword bits, practice your grinding, try different handles on it, use it as a yard tool or shop knife. When you sit down to make your first serious from scratch knife attempt however, start with a known steel, research the proper Heat treating techniques for it, and do it right. Failure to do so can cause many wasted hours and serious disappointment.
