- Apr 15, 2002
The next budget knife I am going to review is the MTech Evolution Tactical Fixed Blade. I bought this knife for $18.19 shipped. It is a little pricier than the knife I reviewed in Part 1 and for the extra $6.00 the difference in fit and finish is quite noticeable.
The blade is sharp- not sharp enough to shave hair but it easily slices paper. The 8CR13 blade is robust, with a full flat grind, drop point and Tinite coating.
The grip scales are “nylon fiber” affixed with torx screws. One scale on this knife is slightly loose out of the box.
The knife is 10” OAL with a 5” blade, full tang and comes with a ballistic nylon sheath with multiple attachment points and carry options.
It is comfortable to hold in multiple grip styles and fit and finish is excellent for a sub $20 made in China knife. There is a small finger choil and the grind is fairly even.
My one complaint is the lower end of the guard is sharp and using this knife without gloves may be uncomfortable.
For someone who is not knowledgeable about knives or is not in a position to spend a lot of money, or someone who just needs a fixed blade knife for hunting or camping this is a viable option on first impression.
The knife is weighty and is fairly thick at the spine. If i get out to the woods to continue work on my surveillance lean-to I will bring this knife and put it through its paces.
My initial impression is that this knife is a solid offering by a company that is known for mass production of low end knives. However for some people MTech or other similar brands are all they may be able to afford or care to buy due to aesthetics or price point.
I am not clear whether 8CR13 and 8CR13MoV are the same steel and haven’t used this knife or tested its edge retention yet. Hopefully I can get it into the woods and put it to work.
Now for the photos.
Comparison with a SOG Seal Pup
The knife with its sheath.
8CR13 steel
The Nylon Fiber handle showing “Easy Grip Ridges” and torx screw fasteners. The left scale was loose out of the box.
There is an oblong slit for a lanyard and the nylon sheath comes with a length of black paracord attached.
After using the knife I will tighten the torx screw to see if it takes the play out of the loose handle scale and smooth out the sharp edges on the guard but I intend to first use the knife “as-is” out of the box.
Now for the photos.
8CR13 steel
