Knives of Alaska Denali Scout - CS Kukri
All Sold. Thanks. Knifes are new in the box, shipped. paypal or MO. US sales only.
1 - Scout $85
1 - Cold Steel Light Kukri $75
The Denali Series Orange Scout is the utmost for the outdoorsmen, with the high visibility hand grips, the razor sharp D2 steel is a plus in any outdoor situation.
•Knives Of Alaska Denali Series Scout Knife
•Type: Folding
•Blade Edge: Plain
•Blade Type: Clip Point
•Blade Length: 3.375 Inch
•Closed Length: 5.125 Inch
•Overall Length: 8.7 Inch
•Blade Material: D2 Steel
•Handle Material: Orange SureGrip
- Made in the USA
17" overall
12" black epoxy powder coated Carbon V steel blade.
Black checkered Kraton rubber handle with lanyard hole.
Black leather sheath
What is the Sure Grip material on the scout? Is it a composite like G10 or injection molded polymer like FRN?
Thanks
Elkins45 - It is Santoprene. Santoprene is a thermoplastic elastomer (TPE). It is the mixture of in-situ cross linking of EPDM rubber and polypropylene. It is supplied as pre-compound material which is able to process by conventional thermoplastic tools. SantopreneTM is a thermoplastic compound that is processed in much the same way as any type of plastic. The difference is that SantopreneTM possesses the same levels of flexibility and durability that are commonly found with natural rubber compounds. Because of the longer life of santoprene in both extreme hot and cold environments, the material is often preferred over the use of rubber.
The handle and frame are drilled and tapped on both sides to provide secure anchor points for the removable/reversible pocket clip. Substantial locking liners are recessed and tightly fitted into each handle, so the overall thickness is thinner (by about 1/8") and stronger than most folding knives. An "open frame" provides an easy-to-clean folder, so important after field-dressing chores are completed.
This is the all the info I found out about the handle material. Hope it helps. Take Care, Steven
Scout & CS Kukri SPF to Hondo66. ARAK second inline if deal falls through on the CS Kukri.
