Knock-off diamond plates?
Anyone tried the cheap diamond plates on Amazon or EBay? (They look like copies of the DMT Diasharp.)
I’m mostly using waterstone now but need something for traveling that I can throw in the bag. Shapton Glass is not in the budget right now.)
If you have tried them, what was your impression? Exactly which make/model did you try?
Leo,
I haven't tried the knock-offs, but see no reason not to buy the real deal, especially since the DMT's are on sale today with Amzn Prime.
I just bought 2 DMT's
the minis are $18.50 for a set of 3
the 6" with plastic box are around $30-$40 each
and the pocket credit card ones are around $10
Mods. if posting these links are not allowed please take down or let me know and I will remove.
Hi,
There are lots of non-trademark infringing unbranded diamond plates out there,
a whole lot of them (all?) seem to be made by "DMD" brand,
like the harbor freight diamond sharpening plates,
The thin 6.69inch/2.95inch #80-#3000 "grit" (or mesh?) ... seem like good deal at ~$3-$4 shipped
as long as you're aware of and dont mind the potential issues
the problems with these they could
take a month before they arrive using free shipping
could need returning back to seller because
come damaged or falling apart,
could be easily damaged despite using the required low pressure with them,
need straightening/flattening (the thin stuff)
need gluing to a backing/board/another thin plate to stiffen up
come too coarse and need breaking in or zero pressure super ultra light lapping to give finer grit finish
unlike the harbor freight plates they have no holes
See The Ultrasharp 300/1200 DMD 400/1200 and the DMT duosharp C/F for a baseline
A local korean/asian/japanese supermarket sells this for $20, its cheaper online and the individual plates can be found for ~$3
Thanks Bucketstove.
i have my eye on these.
https://www.amazon.com/Jewboer-Diam...id=1523983228&sr=8-4&keywords=jewboer+diamond
It's probably the same thing you find on cheap Chinese sites for $5. You pay a bit for the convenience and speed of Prime shipping.
Supposedly these are electroless nickel plated (which would be the same method as the DMT stones) so maybe better than the cheapest of the cheap which supposedly has the diamonds glued on.
I also want something small for a true portable sharpening system. Might just go with tried-and-true DMTs Minis for that. Or the credit card sized one.
The sk11 models on Amazon work well for the money.
That said, I have good luck with DMT. Low pressure, quite aggressive, and not too messy.
Russ
Some of the plates are of sub parts quality and or incorrect grit ratings. Other than that, they should work for the most part. I personally rather buy once and cry once.
You betcha...
