known techical probs with Buck Striders?
hi,
lately i got both the Buck Strider 880T tanto and the 880SP spearpoint. the tanto had a very hard to unlock liner because the titanium liner seemed to really 'bite' into the steel of the blade, but became better when opened and closed more often and now it only locks firmly when i flick the blade open. when i use the thumbstud to slowly open it, the lockup isn't 100% and causes slight vertical blade-play.
but the worst problem is with my lately acquired 880SP. i'm sending it back tomorrow because the blade has excessive vertical play, and i mean big-time excessive! (only after a couple of dozen opening and closing already ;-(........). i think the liner doesn't close up on the blade firmly to lock it properly or something......it's really bad. this knife also seems to have a lot less stronger liner on it (it needs only a slight touch to unlock it), opposite to the tanto, which has a much 'stronger' feel to its liner.........
are these 'liner-problems' common with the Buck Striders? am i right to think that titanium liners are better not combined with steel?
and what is there to do about it, other than sending it back to the shop? (i consider trying to fix it myself if the problems keeps arising on both knives, sending a knife back for repair/replacement s*cks bigtime.....). by the way, do 'real' Strider knives also have this problem, or only the Buck-Striders?
thanks in advance for help,
dennis
Your problem sounds very unusual to me. You may have older versions of the knife that didn't have a flame treated liner. If you acquired it from someone other than a dealer, they may have tinkered with it and affected its operation. It will be hard to say what is wrong until you send the knife in. We will upgrade them and make sure they are in proper working order.
We don't get very many problems coming up with the SB line. They are some of the most reliable, and durable knives in the market. The few problems we have are usually from customers adjusting the knives themselves instead of breaking them in with use. In any case, send it in and we will fix it.
Thanks,
Josh
