- Feb 28, 2003
hey y'all,
got my first official official HI product - a 20" 20 oz kobra by bura.
took my time and studied the sheath - seems spiffy and well made. there's a little tack in the back side holding a flap down - seems a bit sharp to me, might remove it, and use a dot of glue myself - i can see that abrading my pants/leg eventually. it's darned similar to a nearly 12-15 yo older kukri sheath i have [1]
blade doesn't appear to be shaving sharp out of the box, could be one of those tricky "working edges", that doesn't seem sharp, but is. will try on some cardboard later. it's too pretty to use on frozen branches just yet
fit and finish is pretty fantastic for something entirely handmade and crafted as this is, especially for the price, but...
the twist... noticed that the handle alignment seems a bit off - twisted - if the blade is held edge up at "12 o'clock", the narrow points on the butt are at 12:02 and 6:02. is this normal? seems peculiar to me. the handle seems mostly aligned until that point - it's an oval cross-section so would be obviously off otherwise. unfortunately, the twist is such that the upper portion of the butt as held in the right hand is immediately noticeable in terms of a pressure-point/hot-spot if one chokes down the grip. might not matter with gloves on and i'd always have gloves matey - arrrr.
[1] stamped nepal, 3 circles marked at bend on 10.5" blade, stamped NEPAL, brass inlays, horn handle (cracked now - must fix), the h-epoxy is dry now, VERY sharp, well made. it's what inspired me to keep, uh, aquiring - it might just be a tourist piece, but it's fantastically made for just junk :>
bladite
bladite
