KSF Fire Kit
Derrick and Wendy at Knives Ship Free (KnivesShipFree.com) now offer the KSF Fire Kit.
It’s a cool set-up that is designed to be a functional, ..last ditch, …on the verge of hypothermia, …need a fire now, ...kind of deal.
Though it seems to me that many of the components can also be used as part of your everyday fire starting kit.
Here’s the description of the kit from the KSF web-site:
This kit contains everything you need to make a fire under virtually any conditions.
Each kit is contained in an OtterBox 1000 which ensures it is dry and ready to use when you need it most. The OtterBox is easily carried in your pack or on your belt in the OtterBox Holt. Though the OtterBox keeps the kit dry, every part of the KSF Fire Kit is completely functional wet so you can make fire in the most dire situations.
The contents of the kit are:
• Misch Metal Firesteel: A special blend of metals that when scraped with a scraper or the back of a knife produces a shower of very hot sparks. This firesteel produces little balls of molten metal that, with a bit of practice will easily light tinder.
• Hacksaw Blade: Used to scrape the firesteel for sparks.
• Tinder Disks: A specially prepared cotton disk which will take a spark from the firesteel and burn for several minutes to ignite your kindling. The Tinder Disks will burn even when wet.
• Fire Cards: A card specially treated to burn easily and for a long time. If it is shreaded, it will take a spark and work as tender. It contains a basic checklist for how to build a fire with the kit. By folding the card, you can create a lean-to with the Tinder Disks and Fuel Bars and Kindle Sticks. The cards will burn even when wet.
• Fuel Bars: These firestarter bars will serve as a hot burning fuel for your fire which burns long enough to get even wet wood burning. The Fuel Bars burn even when wet.
• Kindle Sticks: Wax impregnated sisal rope which will burn long and hot to help get your wood kindling burning. The Kindle Sticks, once lit, resist being blown out by the wind. Like the other elements of the KSF Fire Kit, the Kindle Sticks burn even when wet.
• Aluminum Foil: When you try to make fire in wet conditions, it is often helpful to have a barrier between the fledgling fire and the wet ground. The foil can be folded into a tray in which you get your fire going and then slide into place under your kindling and wood for the larger fire.
The small Otter Box is quite convenient for this type of kit, as it will keep stuff dry in the worse conditions. Also all the ingredients are designed to work when wet, really upping the odds when the chips are down. As mentioned in the web-site text, there is a Sharpshooter Sheath System carry device (the Holt) that lets the whole deal easily ride on your belt, pack or baldric rig.
OK, ...time to get down to the nitty gritty.
It had been raining here for weeks on end, and we headed out that day knowing there was a good chance for more inclement weather.
My hiking buddies, and fellow knife nuts and Forum members, Tony and Marcelo, joined me on the adventure. We headed down the trail toward one of the local lakes, to a spot on the waters edge that had a nice set up for building fires. It also had plenty of water available to douse the fire, an important consideration when building any fire in the wilderness. We planned on hiking on after out testing, and no conscientious woodsman would leave a fire without making sure it was safely extinguished.
Tony had volunteered to be the fire starter, and though we had started many fires together in wet conditions, I new that the easy tinder’s like Birch Bark and Pitch Pine/Hemlock where not to be found at the location we where headed toward.
Once we reached the spot, I broke out the kit and took some photos while Tony scrounged for some dry material. He did a good job scraping some inner bark off a cedar, and found some seasoned wood that was not totally soaking wet.
Tony’s carefully gathered tinder would probably have work just fine under most conditions, but the incessant wet weather had left even this well scrounged bundle just damp enough to resist the spark from his fire steel.
We started examining the kits ingredients, and decided to give one of the Tinder Disks a try.
This cotton disk was quite stiff from the wax, and not as easily fluffed-up as a Vaseline impregnated cotton ball. After a few minutes pulling and cutting on it, Tony looked down at the hacksaw blade based striker, and, in one of those moments of mental clarity, realized that the sharp teeth on the blade was just what was need to separate the cotton fibers.
Employing the Misch Metal rod, it took Tony a few tries to scrape off the protective coating, but soon it was throwing hot globs of molten metal.
Once ignited the Tinder Disk did burn long and hard.
Next we tried a piece of the wax impregnated sisal rope (Kindle Sticks). Tony used his Bark River Gunny to cut off a small piece and proceeded to tear it apart.
It created a fine little tinder bundle, and, as you can see it these photos, caught a spark and ignited easily.
Once it was almost burnt-out, we added a piece of one of the Fuel Bars.
This potent accelerant burned quite hot, and for long time.
Feeding some of the damp cedar tinder into the flame we had a fire going in no time.
Adding some of the dryer seasoned sticks that where collected, we were soon on are way to having a sustainable fire, even with the wet wood we had at hand.
The bottom line is that these items do work quite well; the Kit could be a life saver when you are wet and cold, and need a fire right now. As well as the supplied tinder’s work in a difficult situation, the fact is that the well thought out components would be welcome in any fire kit, be it one belonging to a seasoned woodsman or a novice working on developing his/hers fire starting skills.
I think this product has great potential. I would say that having a kit like this in your car or Bug Out Bag (BOB) would be a great asset. Even a person not use to starting a fire this way could, use the supplied (and burnable) instruction card, get a fire going with this system.
I also see that Derrick is selling refill packs for these kits, as well as a “Deluxe” kit with twice the amount of consumables. Both of these options make using the components of this Fire Kit as part of your regular fire starting routine a smart move, without sacrificing the effectiveness of the Fire Kit in an emergency situation.
I carry now carry a KSF Fire Kit as part of my standard supplies in my truck; I have also added some of it’s components to the small fire starting kit that rides in my vest pocket (which I wear in the woods daily).
I envision adding one of the SharpShooter/KSF “Holt” carry strap set-ups to my baldric rig in time for the winter hiking season; having one of these KSF Fire Kits along in wet and snowy conditions is a no brianer.
Let me add a few photos of some of the KSF Fire Kit components with a few knives to give a sense of scale.
Here’s one featuring my well loved Bark River/KSF Custom Bowie:
And other showing off Tony’s Bark River Gunny (thumb ramp removed):
Here’s a photo of Marcelo trying to take credit for Tony’s fire by throwing a few sparks form his own fire steel. :rolleyes:
Well, after extinguishing our little fire, it was raining again, but that did not stop us from taking the long way back to the trail head.
I was a great hiking trail, with lots of elevation changes, and some high ledges that offered nice views of the rain swept lake.
Before we reached the trailhead, high winds kicked up and where whipping the tree tops and driving the rain sideways, in fact the top of a large tree broke and crashed to the ground just a few feet from where we were travelling.
My companions scattered, like there was somewhere to hide from the weather in the open forest; but we all got back to the trail head safely.
Of course having the KSF Fire Kit in our gear is just the ticket for an emergency fire in those conditions;
I can recommend it as a useful piece of gear.
Nice review and demonstration BigMike. I agree with the necessity of having some type of firekit that includes different fire starting and promoting options in it. Even though it is ever popular to have the firesteels on the sheath, it is a false assumption to think of that as a replacement to a well thought out firekit.
I can't even comment on how many firesteels I've lost or put down somewhere by accident and had to go digging through my pack to find my kit with everything else in there. Sometimes firesteels work the best, sometimes the windproof matches are your ticket. Also different parts to use as tinder and kindling as need are supremely helpful. This could just be a piece of fatwood to act as both or a combo that includes the high tec trioxane tablets.
I find myself more often than not relying on the KSF fire wallet for my method of firebuilding. However, that doesn't preclude me from taking along a last ditch fire kit. I bet there would easily be room in that otterbox for a few windproof matches and or a mini bic.
In addition to KSF's excellent kit there are a few others that are out there too. Or you can go and make up your own kit. I like the lock 'n lock tupperware like containers that are quite weatherproof, albeit less robust then the otterbox. I can fit two lock'n locks in my 2ndary compartment of my Falcon II and between these two containers can fit much of my PSK contents for fire, water, shelter, signaling and first aid.
Thanks Ken. :thumbup: :cool: :thumbup:
I too carry a variety of tinder on my person, usually some shredded birch bark, a piece of fatwood, PJCB’s and some wax paper, along with several fire staring sources. I trust between what nature provides and what I carry, I can build a fire in short order.
But I build fires all the time, often just to make tea or to sharpen my skills.
But a water proof kit like this makes it easy for everyone to have the needed ingredients along for an outing in the woods or tucked away in their glove compartment in case of a break down.
Like you say, throw in a small Bic and a few waterproof matches and the bases are covered even for the most inept survivalist.
That's got to be one of, if not the best fire kit I've ever seen.
I like that he sells refills, too. There's too many kits on the market that you can't find refills for.
Nice kit Mike. Very well thought out.
Looks like you guys get to have all of the fun. When do I get to come over there and play? :D
B
Maybe someday soon Mike.
I do not think a big convex chopper is in my future. But a parang is sounding awful interesting to me lately :D
B
I’ve got a few big convex choppers on my own workbench my friend, :D
…but my fit and finish is not like yours. :grumpy:
A BA (bad ass) parang sounds cool to me. :thumbup: :cool: :thumbup:
Big Mike
”Scaring the tree huggers.”
Forest & Stream
Awesome review! I could use a few of these to put in my truck and in the cars, and in the bag. I will need to be ordering a few, hopefully before I need a firekit :thumbup:
That’s exactly where these kits rule.
Anyone who lives where winters are harsh should have one in each vehicle.
I am even teaching my lovely wife to spark the steel, and she only drives a few miles to work, but you never know where you might get caught in bad weather.
Big Mike
Forest & Stream
I've really been wanting one of these. Let me ask, Mike, how much room is there in the otterbox to add extras to? Is there enough room to squeeze a mini bic and a piece of fatwood in there? Dang... firekit or Leki pole? :p
Lee, I was able to fit a full size Bic into the kit, along with a small capsule of BJCB’s, and I’m sure I could also get a small piece of fatwood in there.
Big Mike
Forest & Stream
guess i'm going to take a course in photography.dropped it in 60's.sho incredible photos sure gives substanceto instructions.
nice review Mike...:thumbup: those kits look pretty cool, i was checking them out the other day...:)
i wish i was closer to you all, so i could go on some hikes...
Thanks for the review and Pics.
I think this kit would be a real asset to a winter baldric set up like you were describing.
this kit looks strangely identical to a homebuilt kit I posted up last year...... :D
either way, the more fire fixings that get into peoples hands the better!
:thumbup:
