Kukhri ID?
hi y'all;
stumbled across this on ebay while looking for something else, no lion's head or wierd indian style tourist handle, nice bendy looking handle tho., 17.5 in. loa, so i sniped it.
also managed to get this from same seller, which is what i was looking for 1st:
(total: £38 for both)
can anyone ID 'em?
supposedly ww2 era brought back by brit serviceman...
:confused:
p.s. - the sheets in background are the vendor's, mine are slightly cleaner
The knife (sword) on the bottom looks like it could be from the Philipines or Sumatra - I am no expert. Sort of looks like a Bolo, but take a look at the Sandata at Kriscutlery.com, or Frederico's sword pages. You should see similar blades there.
The eastern Asia blade forum at sword forum has people who can ID the blade on the bottom for you.
Very nice khukuri. Is the bolster steel? If so, I'd guess 1st half of 20th century. (and that is just a wild guess)
Bottom piece is a nice parang from Indonesia I think. Others will know more. Not Philippines I'm pretty sure.
Steve
It could be a parang. See:
http://old.blades.free.fr/
I have also seen some blades called "Pira" from the Philipines that look sort of similar, but the size matters, as does the handle configuration.
How long is the bottom knife?
the kukh has a steel bolster i think (not been delivered yet & seller is not up on details) looked a bit pointier than most. will give more deatils on arrival.
the parang (at least thats what i was hoping it was when i trolled thru ebay) was listed by him as an 'african' knife, which i was positive it wasn't. there's another one on ebay uk from a seperate dealer listed as 'a tribal knife' which is almost exactly the same. was fairly certain it's in the parang/klewang/mandau area but as valiant seems to have their site down, could not check to see if they have a simliar one. may be a 'decorator' or a village one, either way for £9 ($15) was not a bad stocking filler. not sure of it's size, but comparing the same wrinkles in the sheet in both pics, it's roughly the size of the kukhri, which was listed as 17.5 in. more details in a couple of days when they show up.
Couple of nice snags, k. Interesting bottom curve on the khuk handle.
The Khuk looks military - with an unusual handle varient.
You have far better chances in the UK to pick up such neat items.
well my new toys have arrived, along with a third oddball knife i sniped as well. looks like a javanese knife of some sort, wood is fantastic, damascus pattern (pamour) is great. the 10.5 in. blade is sharp along the top false edge just ahead of all the decorative perforations & all the way around the knife from point to the hand side of the strange hump near the ricasso area. i'm assuming this not only acts as a finger guard, locks the blade in the scabbard, but also is sharp enough to be used as a secondary chopping or cutting area. blade has a square curved tang that is slid into the handle & can be removed. blade is almost 1/2 thick near grip. saw some similar knives on valiants site last nite (site was up for a while, can't connect now tho).
the small 'parang' has an 11.5 in. blade, 3.5" handle & is sharp as a razor, sits well in the hand, but only 1st three fingers, pinky falls comfortably in the notch at the handle end. looks to me like a childs model, but all non-kukhri knives look small to me.
the kukhri is 18 in. loa, 2 in. at widest part of blade, handle is 4 in. from steel bolster to the steel butt cap. it is a chiruwa type full tang, wood scales & steel pins, ending in two small protrusions which have been peened over to hold the butt cap, similar to the three on my HI Kobra, but without the middle one, the cap is not marked. the bolster appears to be forged along with the blade and does not appear to have any lines indicating it is a seperate piece either at top or bottom, except there is a distinct line (& crevice) where the blade sides meet the bolster which is full of gunk. handle is very comfortable & appears to have been made for me personally, it fits so well in the hand.
the spine is v-shaped, there are two substantial v-shaped grooves from the bolster out about 5 in. along the top of the blades sides. substantial cho is 0.5 in. from the bolster.
blade appears flat forward of the grooving, but when felt has a distinct thickening of the spine starting about 1/4 in below it, so blade is just slightly thinner that distance from spine. blade is then flat to the edge.
tip has a distinct rise in the last 1/4 in. or so, but this may be the result of the tip having been damage in a fall & re-set with a hammer, the edge is symmetrical from above or below, so any damage is not apparent.
the blade has a curved mark just above the cho, mirroring it, including a small blob i cant quite make out. see pics.
blade thickness is just over 1/4 in. & total wight is 500 grams, or 1.2 lbs.
all in all a nice days shopping at ebay!
Nice snags Kronck!!!!:thumbup: :cool: :D
I'm just a little envious of the strange shaped knife. I've thought about getting one of those from the Valiant Company.;)
That one in the middle sure looks interesting. I'd be afraid to hit anything hard with it, though.
aha! valiant site is up today, the one i saw there was called a Kujang
mine doesn't have the fancy carving, but it has a laminated steel blade with 'pamor' & the wood grip/scabbard wood is naturally figured such that carving would only detract from it. (valiant's is not listed as damascus,but as 'spring steel' with various etchings)
I like yours much better Kronckew. I was tempted to buy one of those by valiant before. But I do not like the fancy etchings.
two things i hate about ebay:
a. they have zillions of 'offerings' from "china, UK" (to bypass the location filtre i guess) for some (possibly) interesting chinese swords (and chinese made katana - 'will cut iron') with really embarrasing use of hyperbole & they all seem to be artificially 'antiqued'. if they listed the things as repro's & didn't bury them in horsedung to 'age' them, i might be tempted tho the listed price of £0.99 with postage of £60 does not impress me much.
b. filtering for 'damascus' brings up all these items, like 'Wonderful damascus skean dubh' which turn out to be 'etched pattern' stainless steel
they do serve some purpose tho in distracting the other people away from the occasional gem that can be discovered by deeper investigations...
at least valiant is honest & appears to have a simliar approach to customer satisfaction as HI, but i'd rather the misleading 'etching' were actually not there, bare polished steel would be more to my liking if they are not laminated. guess it depends on yor sources. he's got a 'damascus' one listed there as a 'Kudi' rather than a 'Kujang' that looks better, tho less contorted.
You need to take a peek in Stones book of historic weapons. Mine is in storage. From memory the bottom 'parang' is a golok.
Good price BTW, the kukhri is worth more than that
