Joe,
I'll agree with the 15" AK (or any 15" as the way to go if you'll be carrying the knife long term on your person in a wilderness, or primitive environment).
Wetness Issues:
If you use the blade constantly and wipe it down with a rag and apply Marine Tuff-cloth, it'll do well for you in both the Jungle and Mountain environments. Heck, even if it rusts, it's so thick it'll take a lot longer than 4 months to weaken if it's being used. The edge won't rust if used constantly and honed and resharpened. The mountains of Chile are rainforest and therefore wet, much like the Olympic Range in Washington State if you've ever been there. So you'll be wet a lot either way!
A bone-handled model will serve you better if travelling between a humid and high altitude environment, due to wood expansion and contraction from temperature and humidity changes.
The wooden sheath/scabbard wrapped in leather will need a little more caretaking, but it's easy. Linseed oil, rendered animal fats, or vegetable oils poured into it, then rolling the sheath around to spread it evenly inside and allowed to soak into the wood will keep it conditioned and wick water from the blade a little better. Oil on the outside of the sheath is a good idea too, and candlewax can be applied in certain parts (like the scabbrd hole) to work with the oils to keep the leather from pulling out. When the leather gets wet, it can stretch easily, and when it dries again, it can pull out from shrinkage. Also, drill small holes in the bottom of the scabbard to let water drain out. The thread on waterproofing is mentioned above -- there are two threads on it I think...I mentioned some natural methods there as well for waterproofing/protection... Sno-Seal on the outside
might be okay if you have the inside oiled and good drainage holes on the bottom. If no drainage, you'll keep as much water in from Sno-Seal as out. Result: one wet knife!
Take a plastic trash bag along with you and wrap the whole knife and scabbard in it when not in use, or when crossing water (make sure you've got it dry inside and out first). Or just pop it over the whole knife and scabbard while on your waist and tie it down while walking.
Uses in the Wilderness for Khukuris And Other Stuff
The 15" Khukuri also makes a fantastic draw knife for scraping and shaping wood into useable forms. Hammering anything with the back of the blade is easy (put a piece of wood to protect the blade -- why damage of work of art?
), and splitting logs and other wood is a breeze -- you'll have shelters and racks and all sorts of stuff up and running in no time!
The Karda, or small knife, included with the Khukuri, will perform outstandingly for smaller whittling tasks for shelter construction and other wilderness tasks, and cooking. The Chakma, also included, in addition to being a great blade burnisher, also makes a great hide scraper and separator when cleaning and tanning. And a helluva butter knife! You can stir your tea with it, too...
Of course , this all depends on the type of shelters and work you'll be doing, and your living conditions...can you elaborate on the types of work and living conditions you'll be in, and length of time? In other words -- daily excursions from a house into the wilds, or extended campouts, etc...
I've found in heavy brush when I need to travel light, the
size of a 15" Khukuri as opposed to larger models works best -- it's less bulky on your person, and less heavy. I let it ride on my right hind/side on my belt, ( I'm right-handed) for same side draw in those conditions -- it gets caught up less when {edit} on the hip (end edit)than when up on your back, and is in easy reach for bushwhacking. Plus, the 15" is usually less tiring to use than a 20" incher...
Be certain your chopping technique is solid and keep your legs out of the way and body out of the way, whether bushwhacking or chopping sticks downward! These knives are heavy for their size and will go through things suprisingly well -- better than a knife or hatchet, and they'll continue through your leg -- so off to the side as you chop...or "bobbitization" may result
Practice with it before you go into the bush...and rest
beforeyou get too tired, or dangerous carelessness can result.
Hope this has helped, and have fun on your journey! Let Bill and the rest of us know how it goes -- BTW, I use HI Khukuris exclusively -- not that the others aren't good, too, but I like them the best and Bill is the most genuine person I've had the pleasure of knowing and dealing with in a long-time.
Peace,
Brian Jones
Co-Moderator
Wilderness & Survival Skills Forum
Suburbia: Where they tear out the trees, then name streets after them.
[This message has been edited by Brian Jones (edited 01-07-2000).]
